Topic: rather new to the site (Read 2901 times) previous topic - next topic
I vote for the 5sp swap also.
I have a t-5 from my dads old 89 5.0 stang sitting in the garage if you need it. That's if it will work behind a 2.3 I also have a couple garret turbo's laying around you can have for the right price except the t-88's I don't think your ready for those yet.
98 Supra TT
04 SVT Cobra
02 BMW 5series wagon-DD
Quote from: ThunderbirdSport302;316203
So it's an auto car? Bummer...I'd throw in a T5 if it was mine ;)
I'd also let the engine warm up a minute or 2 after starting regardless of turbo or not.
There's a guy I work with who revs the hell out of his engine on startup....just in the last few weeks, it's been smoking pretty hard when he starts it. I told him he's tearing it up, all he says "I don't care." Idiot. :D:punchballs:
He says when it blows up he'll put another 350 in it....yeah right. Can't even change his own oil or plugs! :hick:
If nothing else, let the oil pressure get built up before taking off ;)
Haha yeah its auto, at least for the moment.  The tranny is done so it needs to be replaced. If I choose to get it,  why not do a 5spd swap? Btw that guy sounds like an idiot lol.
01 Acura CL-Type "Nasty" S
I helped a buddy out with a 5sp swap in a mitsubishi and it was a PITA. Are these cars being that they are older easier to swap from auto to manual? Also, how about shift kits for the auto's?
98 Supra TT
04 SVT Cobra
The T5 from a V8 Mustang may not work, as I think there's a difference in the of the input shaft. That, and the gearing will leave a lot to be desired, as the 2.3t T5's had a deeper first..
Wish I still had the one I sold about a year ago...although shipping would be a beeyotch to where you are lol
The 2.3 bell bolt pattern is different from the V6/V8's, so if you can use a V8 T5, you'll need a TC bell.....since the '87-'88 used a hydraulic clutch, you'll probably have to swap in all that stuff.
you'll need:
pedals from '87-93 5 speed Mustang
clutch cable
pre-'87 TC T5 bell (XR7 will work too)
flywheel and blockplate from a 5 speed TC
obviously a clutch ;)
There's probably a couple things I'm forgetting, but that's the gist of it.
If you search for a4ld to t5 swap in the drivetrain section, I'm sure you'll come up with a lot more and better info :D
Luckily for Mike I'm sure "pick-n-pull" has a couple cougars and tbirds. Also there's a shop in Yorktown off of production drive that specializes in fox platform cars.
Also, is this the car you speak of? I assume so.
http://norfolk.craigslist.org/cto/1643496910.html
Have you seen these?
http://norfolk.craigslist.org/cto/1647582309.html
 http://norfolk.craigslist.org/cto/1659785404.html
98 Supra TT
04 SVT Cobra
Luckily for Mike I'm sure "pick-n-pull" has a couple cougars and tbirds. Also there's a shop in Yorktown off of production drive that specializes in foxbody cars.
98 Supra TT
04 SVT Cobra
Quote from: CobraGurl;316218
Jayda your assumption is correct, that is the one I speak of. I have actually "hit up" the person about the first link of the second question you ask. I have to wait til I go to work, to see what was said back if anything. I haven't seen the second one. That swap is gonna take A LOT of work if I were to go thru with it. But we will see.
What?
98 Supra TT
04 SVT Cobra
Quote from: ThunderbirdSport302;316217
you'll need:
clutch cable
Thanks for the info, something indeed to look into. With so little time I have right now, with a possible deployment. Well see how this goes though.
