Topic: bolts needed (Read 1556 times) previous topic - next topic
bolts needed
What about the local Lowe's?They have all kinds of bolts,and they work great...and cheap....and fast.....
bolts needed
I have a whole set of Explorer bolts (NICE),but they are too long.The lip on the Explorer aluminum pan is pretty thick.Can you post a clear pic of one of the bolts?I may have some.I have about 40 pounds of fasteners in the garage.IF I have them,I'll send them your way.
bolts needed
No problem.I'm going to go dig around now and see if any of them look familiar.
bolts needed
Do they have little built on,but loose,washers?I have 9 of them,but they don't look long enough to go through the pan,gasket,and rails.
bolts needed
they are a bolt with a  no washer. I almost thought they were valve cover bolts when I gathered them last night.
bolts needed
I'll look again,I probably have them. If I do,how many?
bolts needed
I think I have some.I'll let you know tomorrow after work.If so,I'll ship them up to you stat.
bolts needed
if vinnie doesnt have them pm me and i can send you a few
Junkyard Cat
bolts needed
no worries, took a trip to the local yard and pulled a hand full and found an oil pressure sending unit extension!  SCORE!! :D  thanks anyways guys
