Topic: Parting out 88 tc **LAST CALL** (Read 4164 times) previous topic - next topic
Quote from: 88CougarGT;317507
Hows the trunk carpet set?
The trunk is full of stuff right now, when it is cleared out, I'll get some pics and let you know.
1987 Thunderbird 3.8. Sold :(
My interior trim is KB on an 85 cougar. It's two different shades of blue on the door panels. Are the door panels in good shape and can you get any pictures. Mine are kind of shot. Shipping to 32765
Quote from: 85cougar;317685
I will check, I think the door panels MIGHT be spoken for.  I will find out for sure and get back to you.  Do you want just the panels or the arm rests/ map pockets as well?  Panels are in good shape, the map pockets, not so much.
All of my pieces could probably stand replacement. The fact that they are screwed on helps keep the armrests, etc in place and fairly solid. I don't know if the color combo is popular or not, but we are trying to get what we can as we can afford to - if and when we can find them. Hard to come by though.
Quote from: vinnietbird;315910
Hang on to it for me.I'll gather funds.Probably be Wednesday of next week.Can you wait that long?
I've had the panel ready to ship for awhile now. You have a pm.
Answered.
This car will around for one more week.  The rear is spoken for, The wheels are available, though I am hesitant to ship them.  PM me right away if you need anything.  Sunday is likely the last day I'll be able to pull parts.
Need the Head Light switch with the built in dash light dimmer rotery switch.
87 TC
Quote from: bigbada1;324887
You have a pm.
Reply #39
Any news about the door panels and armrests? Still interested in pictures if you still have them. Mine look all warped like someone pulled them out of a lake(rippley)
Reply #40
Quote from: 85cougar;324949
I will try to get pics this weekend.
Reply #41
Thank you sir!
Reply #42
If the rear axle is getting sped with the rest of the car, how about the rear drivers side caliper setup? eg caliper, bracket, bolts, hose, etc
Also, I'd be interested in the front spindles.
Thanks,
Chris
87 Thunderbird 5.0
Engine: 97 p-code explorer block, heads, and intake; 88 HO cam, 1.7 RR's, A9P, Kenne Bell 2.1 Flow/Blow 8psi, 42lb injectors, LMAF, 75mm TB, Tuned by Don Lasota
Trans: 02 Stang 4r70w with Baumann TCS
Suspension: Front: 03-04 cobra springs and struts, TC rack. Rear: CHE arms, ChuckW shock mounts, Bullitt springs and shocks
5 bolt with 95 mustang front and mark vii rear.
TC 3.73 L/S rear
03-04 SVT Cobra 17x9's with 275/40r17's.
Reply #43
Quote from: a77cj7;324996
Thanks,
Chris
You have a pm.
Reply #44
Quote from: 85cougar;324966
Thank you sir!
I pulled the door panels today.  The speaker grills are not in very good shape, both are broken at the top where they snap in.  The map pockets are scuffed up as well.  The screw covers on the pull straps are missing.  One panel has a bow in it from sitting in the trunk.  Arm rests and the panels themselves are in pretty good shape, just need some cleaning.  I will get pics when I can.  PM if you are still interested and we will conclude business there.  Thanks!
