Topic: Cougar Parts and more.... (Read 1871 times) previous topic - next topic
Reg hinges from an 86 and $10- sprung hinges from an 88 are $20.  I have the wiper motor and switch for interval wipers, let me check to see what else is needed for the swap.
John
Quote from: hcor;316280
THANKS for checking and please send me a PM about them once you decide what you've got and what's need to convert my '86 XR7 from non-interval to interval please (that way I don't risk missing your message ;-)
1986 Mercury Cougar XR-7 Turbo-charged 5-speed.
Owned 22 years.
PM me reference the hood springs so we can set something up.
We are in finishing up the new building for our parts and are sorting through everything so please bare with me.
 V8DEMON- pm sent
 COUGARGAL- I am sorting through the parts and looking for the interval governor to complete the change over for you.
John
Quote from: hcor;316961
We are in finishing up the new building for out parts and are sorting through everything so please bare with me.
 V8DEMON- pm sent
Thanks!  Let me know via PM when you locate everything (so I don't risk missing the post)
Owned 22 years.
Thanks for the Parts and the Wiring Diagram!
I'd just like to ask one question, if I may.
Your schematic (and the ones in our Electrical Manual) show a different connection between the Wiper Motor for the Interval set-up and the Two Speed Set-up.  The Motor's for the interval wiper has 5 wires and the two speed motor has 6.
In the box of parts you shipped... the motor has the same connector as the one mounted on CougerGal's Cougar.
I'm leery of taking out that existing motor (and breaking something ... like I usually do :D) if that isn't necessary.  Do you know if the Interval & 2 Speed Set-ups use the same Motor ??
Thanks !
I am not sure if they use the same motors, I sent the same motor that I have on my 86 with interval wipers. I'll look at the wiring diagram again tomorrow when I get to work and check into it for you,
John
Quote from: hcor;319985
That'll work... Thanks !!
sorry got crazy busy at work I'll try to print out another diagram and check it out this weekend
John
the 6th wire looks to be an external ground, probably for park. with the intervals it is grounded through the governor.
John
Quote from: hcor;320333
So... just to comfirm .. the motors are the same in both configurations..
(Not trying to be dense... just got in from work..)
Quote from: AlabamaWildman;321842
I looked into this too ...the answer is...... yes the motor is the same :D
Quote from: hypostang;321857
THANK YOU! !! !:bowdown:
