Topic: Updated Pics!!!Thinking of painting my intake... (Read 2938 times) previous topic - next topic
There's an upper and lower intake.Look at the picture of my engine on the first page of this thread,and you'll see how the upper intake goes over the driver side valve cover,and in my second pic,you can se the lower intake EASILY.
Here is what i did ford blue on the intake and throttle body. Black on the valve cover, also sanded the ICM then clear coated it all. It aint the best but it will do untill i do a complete teardown and rebuild of the whole car.X
X
X
I like the Ford blue idea;)
Quote from: daminc;314233
started mine. still getting the casting lines out.
You need to take that bracket thing off on the front of the intake. Also you can remove that vacuum fitting that faces forward on the lower front of the intake and plug the hole.
