Topic: Took a trip to the closest Boneyard. (Read 7121 times) previous topic - next topic
Reply #60
Do yourself a favor and take the coolant tube off.  The coolant tube has one nut holding it down.  Under that nut once the tube is off is a stud with another nut on it.
41 Dodge Luxury Liner Sedan
78 F-100 2wd flareside
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
90 Stang LX 5.0 5spd
93 F-150 4x4 ext cab
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Reply #61
Pssshhh.... i knew that....[didnt have a clue].....
Reply #62
hey another quickie, Im about to go cruising and call it a day but how do i detach the fuel rails to get that collant tube out of the way?
Reply #63
Remove the 4 8mm (head size) bolts that hold the fuel rail to the intake.  Use a prybar or a big screw driver to pop the rail off the injectors.
PS. Buy new injector O rings when you put this together.  Fuel leaks suck.
84Turbo Coupe
84 Thunderbird Élan
85 Thunderbird 3.8
88 Turbo Coupe
88 Mustang GT
96 Mustang GT
98 Mustang GT
99 SVT Cobra
06 Fusion SEL
14 Fusion Sport
Reply #64
ill remember that lol. I have a new fuel rail and injectors already fitted onto the gt40 so ill see how that goes... Got it allll apart... and by the way no one told me there was TWO bolts in the middles instead of going with the pattern of one bolt in the middle of every injector.... i found them and it popped right off haha. So its all broke down now im gunna borrow a buddy's engine stand or just buy one from someone cuz the new ones are too expensive and then start on the bottom side... wish me luck lol I dont even think i need to take this thing apart honestly it all looks so good! the cylinders are smooth....oil was old but clean, the filter that prolly hadnt been changed for fifteen years didnt have shavings in it or anything...
