Topic: mustang aluminum valve covers (Read 2431 times) previous topic - next topic
how or what do you use to strip the factory coating off these?
I've used carb cleaner, water, and Strip Klean. this stuff just gums up and clogs my wire brush.
1979 Ford Fairmont
[/B]
media blasting?
__________________
Twin '85 TCs
White/ Grey 2-tone
I don't see one in my garage, but I got it off once it dried.
1979 Ford Fairmont
[/B]
Bead blasting. I did that with mine then polished them.Or,bead blast them and spray on some clear coat.
(threadjack)
Have you guys used the carb style on the EFI setup motors??  If so, how didya do it?
Mike
I used Engine Brite , then Dawn dish liquid then I ran them through my dishwasher :D
 Of course I painted mine wrinkle black instead of polishing them
Quote from: mcb82gt;313728
(threadjack)
I tried it,not worth the time and effort.The oil fill on the passenger side is under the throttle cable bracket,and the oil fill on the driver side is under the intake.Just use EFI covers.If you don't like what you have,save up the money til you do,do some trading,whatever,but do it right the first time.
What does the wrinkle black look like and where do you get that paint from?
:burnout:
I bought the paint at ADVANCE Auto parts  and it looks like this
I likey! I have some bed coating spray I should try then.
1979 Ford Fairmont
[/B]
Quote from: 32VFoxBird;313813
Are you sure it will hold up to the heat??
Mike
I haven't a clue, but there's one way to find out.......
1979 Ford Fairmont
[/B]
Quote from: mcb82gt;313831
I could only find one case of where someone used the bed coating spray to paint something engine related and it happened to be a motorcycle. It looks like it held up everywhere except top end, there is started flaking. I'd just use wrinkle black high temp engine paint....
It does look like bed liner coating. I am looking to do a hammer like finish on my valve covers and intake. I just need to find the stuff.
:burnout:
Quote from: 86caprirs;313932
KRYLON makes hammer finish rattle cans , and Wal- Mart stocks it
