Topic: Thundercat Dyno Day (Read 29750 times) previous topic - next topic
Thundercat Dyno Day
Reply #150
Ray , Some of those pics are not showing either. :poke:
Dan & Paula ;)
Thundercat Dyno Day
Reply #151
Supermotors is really glitchy, but it's free...so what can you say. ;) It's working as of this morning.
Thundercat Dyno Day
Reply #152
Here are the graphs for two runs.  One with the caps on, the other with the caps off.  They're pretty similar, averaging about 8 points higher after 4,400 RPM.
Unfortunately the chart with the specific read outs is too big to download...
Thundercat Dyno Day
Reply #154
Quote from: mercury-man;329872
Hum.....Thundercat Dyno Day II ? 2011 ? :headbang:
I'm all for it, sir :headbang: :burnout: :headbang:
Thundercat Dyno Day
Reply #155
i demand a recount!
i got the car back together after a list of minor failures including the header, a power distribution problem that was shuttin down everything, and a blown water pump. now this car is a completely different animal to drive.
the boost is sooner, smoother, and will actually hold at 20psi thru a whole pull vs. wasting energy thru the header crack. the peak numbers might not be much higher, but i garaun-dang-tee the curves would be much more broad.
