Topic: Grabbing Pavement (Read 9257 times) previous topic - next topic
Grabbing Pavement
Reply #45
Quote from: 32VFoxBird;314919
the 7.5" will last awhile with a stock motor and tires. It's when you're putting 300 hp to the wheels with stick tires, you'll break it. But only a few here are
making that kind of power and drag racing on a track.
Ummmm I make MORE......
Like I said, spider gears.....
Grabbing Pavement
Reply #46
A posi will help protect the spider gears.  Full locker is not a good option for a street car and illegal for the track unless you upgrade to eliminate you c-clips.
I guess that I was not saying that the 7.5 is complete junk (maybe very weak went too far).  What I was trying to say is that I would not want to put any money into a 7.5 when you can buy a fairly cheap 8.8 and not have to worry about it in the future.
I have an 8.8 in my Cadillac 500 powered T-bird running 11.45 and with a slight lift on take off and so far so good.  I do not think that a 7.5 would survive one run.  My upgrades are a truck posi, 31 spline axles and aftermarket rear cover.
There is a reason that Ford use the 8.8 in the Turbo Coupe and Mustang 5.0
When I was a kid I had a 1966 Dodge Dart.  I spent money on the stock, small, weak V-8 rear only to have it break twice.  Once I upgraded to a 8.75 mopar I had zero problem and saved a lot of money.  Just trying to pass on my experience.  First thing I always do with a new hot rod is make sure the rear can handle the power.  I have seen many broken rears at the drags (mostly GM).  It is very embarrassing to hear a clunk and not move at the starting line and you sure don't want to do it next to a Honda on the street.
TED
Grabbing Pavement
Reply #47
Quote from: V8Demon;314932
you seem to have a reading comprehension problem.
1979 Ford Fairmont
[/B]
Grabbing Pavement
Reply #48
Quote from: 32VFoxBird;314938
On your period?
PMed.
There are examples of 7.5 rears in the 10's..... These  are fully built of course, but even one with mild upgrades can stand quite a bit of abuse contrary to generalizations presented preceding this post.
Been a while since I put a name on the ignore list.....guess I'll go do that now....
Grabbing Pavement
Reply #49
I was only backing up your statement about them. I know they can handle somr power, but if you're making any real power you should just get an 8.8". why build a 7.5" when an 8.8" can handle it?
I never said a 7.5" couldn't be built to handle 10 sec slips. You're putting words int mouth.
1979 Ford Fairmont
[/B]
Grabbing Pavement
Reply #50
I always see axles brake, 7.5 or 8.8. It's not always pretty either.
Grabbing Pavement
Reply #51
my built 7.5 rear end with 3:73 gears has handled all the abuse of a v6 nitrous motor and hasn't messed up yet.
