Topic: Anyone have heads for sale?? (Read 6646 times) previous topic - next topic
Re: Anyone have heads for sale??
read the thread.. ;)
it's possable that it's just a basic casting. i never looked on my heads to see what number is stamped on it... i just saw that those where stamped 6025.. but i would just make sure what your getting before you buy..meaning valve size.. if he wants to much for them. it's not worth it since new ones are under $1300.00 shiped to your door step..
i would just out right ask him what he wants for them instead of the back in forth with make an offer.. ask him whats his bottom line..
if he wants between $600.00 and $800.00 cool maybe $900.00 tops and they better be damm good heads.. for that price used.. but any more i'd just say screw it and buy new ones..
Nick
I was thinking the same thing. Plus If I get screwed out of say $800 I can forget about getting heads at all this year. So I really can't risk it with anyone I don't know. I have little over 2 grand to buy heads,cam,rockers,push rods, gaskets, timing chain,injectors, and ma meter.... I'm reusing my cobra intake and 65mm tb.
Quote from: thunder306
65mm throttle body fine you won't need bigger..
now you say you have a little over 2G's to spend ok..
60379 heads, $1300.00
ford motorsport 1.6 roller rockers.. i don't remember the right price buy they are under $300.00 :EDIT: summit $249.95
push rods, about, $50.00
cam trick, flow stage 1..$139.95
ford motorsport timming chain, about $70.00
ford motorsport injectors, $219.00
gaskets about $50.00 for all of them...
mass air meter, i would only use PRO M but their OOB!  :disappoin
so punt!!! on that one.. or try ebay for one..
total with out the meter is 2078.95 + tax or shiping new total is ..$2028.90ALL BRAND NEW!!!
not bad..
Nick
While that is all true, you can buy the rockers off of ebay for about 100-150,you won't need hardened pushrods as the eddy heads don't require them and injectors you can pick up off of the corral for 100.00.
everything else i would go new,and in that 2078 est there was no price of a maf meter,used c&l will run you 150.00 with power tube.
So all that being said if you knock off 270.00 for the used part portion you can get your meter and still be able to afford the 100.00 arp head bolt kit you need for those heads.
As for the pics of those heads,they definetly have been sandblasted,decked and checked for cracks(pretty sure valves/seats have been done as they have been at the machine shop).
All in all they look to be mint,checked used heads,if he wants 750-850 i would definetly pick them up and save yourself an additional 500.00 on the heads and go get yourself an icecream with the extra cash you saved.
O and 6025 is stamped into all of eddelbrocks ford castings,they then take the casting and machine it for whatever application it will be used for.
I thought the same thing when i got my heads so i called edelbrock and that is what they told me.
One last thing,since the heads have been decked(and they have)you must find out exactly how much and then use the appropriate shims under your pedestal mount rocker arms to adjust pushrod height.
Ok I got a price, $750 shipped.. I just emailed to ask how much the heads were decked...
ok, he emailed me back and says:
the heads had about 5 thousanths taken off of each one.
So does this matter? I don't know I haven't played with engines or heads in like 8 years :(
help me out what you guys think? buy em?
at this point it's all up to you.. your call...
with .005 off each should'nt be bad at all maybe a cc or two off cc's from 60cc's that they are milled at from edelbrock..
and on one small note  i said $2078.00 with out the mass air not with it ;) and as far as C&L:yuck: i plea the fifth
oh and add ARP head bolt to your list like dominator said ;)
Nick
750 shipped,GOOD DEAL,i would buy them up.
Essentially your getting a set of heads that have had all the machine work done,are guarenteed flat and him throughing in the shipping is perfect.
As for the .005" decking,i'm not sure at what point you have to use the shims,if you talk to your local machine shop they should be able to help you out. :D
If you go to cranecams website you can get the instructions on how to install your rocker arms.
They say that when you torque the rockers down to:
Turn the bolt by hand until there is no clearance between the front roller and the valve stem with both valves in the closed camshaft position(compression stroke).
Slowly torque the bolts down to 18-20ft/lbs approx 1/4 to 1 turn.
If you can turn the bolts more than 1 turn to acheive torque you will have to shim the pedestal,a thick shim represents 1 turn.
That is basically quoted from there instructions i printed off.
The .005 ain't nuthin', I had my Trick flows cut .010 when I had the heads off a couple of years ago..
Iv trying to get him down to $700 for shiznits and giggles. I'm really in no rush so if it doesn't work than I'll go for $725 with the old meet me half way line... wish me luck :)
Wow that was easy just got off the phone with him.. $700 shipped, heads ship out tomorrow at noon :)
Sweet,awesome deal man,hope they work out well for ya,i'll post results on mine when i  do my mods in a few weeks.
