Topic: Oil Pressure (Updated PG 3) (Read 4292 times) previous topic - next topic
Quote from: FloridaCougar;313070
heater core. I'm about to get a dash cap, new carpet and floormats so I'll have to fix it. Wishful thinking, but there's not an off chance that it could be caused by something else?
Manual heater control or ATC?
Quote from: softtouch;313140
Manual.
The A/C should never run with the function selector in the vent or floor position. It will run in defrost or mix/Hi Low.
The temperature blend door is mechanically operated by a control cable from the temperature control lever. If it is stuck in the cool position, the air will bypass the heater core.
After a drive feel the heater hoses to see if they warm up.
