Topic: Finished the 5 Lug! But.... (Read 9952 times) previous topic - next topic
Reply #45
Finished(For the most part) - Pictures on the First post!! Found MOOG Ball joints at Baxters for a very reasonable $47 each.
Reply #46
Quote from: ThunderbirdSport302;316155
I don't know that I'd trust a coat hanger to squeeze a spring down.:hick:
:eek:
Some spring shops will compress/band the spring for you. Still must be thrilling to handle it knowing all the potential energy...:D
tbirdregistry.com
26480
27373
Reply #47
Man, it was hard enough finding a shop to do the bushings on a Sat, I wouldn't have wanted to find one to compress the springs. Ended up using an internal compressor, which worked OK, not the best, took a little bit to get it out once the springs were in, but what are you gonna do? Steal Kitz's jaw type? :D
Compressing springs
Reply #48
I USE SPRING HOOKS, COMPRESS SPRING WITH AN OUTSIDE COMPRESSOR, INSTALL HOOKS(2) ON SPRING WHERE IT WILL BE ON THE INSIDE, (THIS WILL PUT SPRING IN A "C" SHAPE ONCE THE COMPRESSOR IS RELEASED) THEN IT WILL FIT IN THE POCKETS PERFECTLY WITH NO COMPRESSOR ATTACHED, JACK INTO PLACE AND PUT THE LOWER BALL JOINT NUT ON, JACK A LITTLE MORE AND REMOVE THE HOOKS (15 MINUTES A SIDE):shakeass:
Reply #49
Yes, well Mr. Shop manager, not all of us have your considerable resources  :D
So, no comments on anything? Not the rims, the angles? Bummer.
Reply #50
Looks Great!
And thanks for the pics of the SN-95 A-Arms. :cheers:
I actually really like how they sit, I need to go out and measure the back spacing on my "New" rims (17x7.5).
Reply #51
Hey, thanks Romeo2k, I liked it too, but I would have needed wheel spacers for the back axle since they sit so far inboard., and I was a little concerned with the cornering, as well as only 1.25" of engagement with the tie rods.  I also think I heard something about the angle of the tie rods....etc etc, probably could be fixed with a bumpsteer kit though.
I Can't remember what the inset of the old rims was, do you maybe have a picture that would show me how far inward the top of the rear tire is in relation to the fender well?
Reply #52
Humm, I'll look into a bit more when i dig into the front susp.
I measured a 6" Backspace on my rims also, But they have pretty fat tires.
And Nope, But i can go out and get some! :hick:
It's completely stock right now, But very soon I'll be switching out the whole rear setup.
Reply #53
Heres some middle of the night shots:
Front:
And you thought your car was dirty! :hick:
Reply #54
Yes, I was definitely mistaken:D Thanks for the pics, I'll compare this week and let you know if the inset has changed much.
Reply #55
Ok, well, had to chop ~1/2" off the inner tie rods to get toe corrected?! Anyone else have this issue? Very distressing since no one else mentioned it.
Also, seems my 6 inches of backspacing is either too much up front, or I am missing a turn stop, because I've already scrubbed two wheel weights off in hard turns. Seems like the Control arm is a likely culprit but I haven't looked closely.
Any ideas or thoughts are appreciated, thanks guys!
Recap:
Fox arms, SN-95 everything else.
18x7.5" with 6" Backspacing rims.
Had to shorten tie rods.
Reply #56
Ok, so, I looked a little closer, and apparently the rim/tire ishiznitting the K-member?! I suppose I should have taken pictures, but I was at Les Schwab. They aligned it and rebalanced the tires. For some stupid reason, I can't get to the ideal camber on the DS strut tower. It is within Factory spec, but not optimal.
I am beginning to regret these rims.....
Reply #57
You have FWD wheels on a RWD drive car. You're going to have clearance issues. You need wheels with less backspacing. Plain and simple.
1979 Ford Fairmont
[/B]
Reply #58
Yeah, I know, but they look so darn cool! I guess I'll be considering wheel spacers front and rear, though the aligned stance actually looks pretty good.
That still doesn't explain the tie rods though....
Reply #59
Humm...
Wondering if wheel diameter isn't a major factor in rubbing as well...
Do you have a lot of rub, or just a little?
I thinking the 18" (6" Backspacing right?) rims and/or tire profile may be causing you the troubles there.
Dunno~Just thinking out loud.
We should have about a +44mm offset.
And its looking like +38 is roughly the max for our k-frame...
So to achieve that (38mm) the chart says we would need a 0.25 spacer? (or larger) on each side in the front (equivelant of 5.75 backspacing).
But i (Think) the max recommended offset is +32mm, So we would probably need a half inch spacer at a minimum per side.
Really wishing i could get a hands on with this, But i'm still gathering the needed parts for the front + i have to change the bolt pattern and i have other projects ahead of it in line. >.<
I'm learning as look into this stuff so i could be way off or right on~Would be great of someone Experienced in this area could chime in.
