Topic: Rocker arm assemblies and tilt lever.... (Read 2562 times) previous topic - next topic
I'm in.I'll get them out to you.I'll toss in a bead blasted,ready to go thermostat housing as well for you.
I need the rocker assemblies as if I am starting with none at all...the little metal bases,the fulcrums,rockers,and bolts.Thanks a lot.I still have your address.They'll go out asap.
do you still have the crown vic throttle shaft i sent?  I need the little green grommet if you can get it out in one piece ;)
I threw it away,BUT,I just HAPPEN to have another complete Crown Viv t-body and I'll send the throttle shaft to you,untouched.How about that?
if you want I'll send that throttle body so you can extract the idle screw too :rollin:
I would love to,but I loaned my screw/bolt extractor kit out about a year ago and never got it back.Run it by any machine shop.Probably a $5 job.
Do you have what you need? Why are you looking for stock?
I got something if it don't work out,.
I'm going to put them on the current engine so I can sell the roller rockers to fund some other stuff for the Sport.If 88Turbo has what I need,then yes,I'm good on what I asked for.I'll leave the thread open until the parts are here.
I'm probably going to install 1.7 roller rockers on the "P" engine.What do you have Kitz?
Quote from: vinnietbird;309893
I need the rockers and related pieces for a 5.0.Just stock parts,uber-cheap or trade.
I also need a tilt steering lever.
http://cgi.ebay.com/ebaymotors/UPR-Ford-Mustang-Billet-Designer-Tilt-Wheel-Lever-94-04_W0QQcmdZViewItemQQhashZitem19b98a2cddQQitemZ110487022813QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
http://www.uprproducts.com/mustang-billet-designer-tilt-wheel-lever-polished.html
This is the one I have but a guy on ebay sells it for $10 shipped but I can't find it
http://www.uprproducts.com/mustang-billet-regular-tilt-wheel-lever-polished.html
A list of all types
http://search.uprproducts.com/?vwcatalog=yhst-37354654005614&keywords=tilt
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Thanks a lot for that info.I prefer black if possible.I like that subdued look.I may go that route if I don't end up getting one,I'm patiently waiting.
Well, I dug out the spare column I have and checked the tilt lever but its broken off.  Sorry man.
Vinnie, I'll try get you a tilt lever as soon as I can get a day off and the weather is good. I know for sure there are a few out there. I need to go back and find a few things for myself. I also still have my 1984 style black one but I should have no trouble getting the correct one that you want.
If it's a black lever,and it'll fit my column,I'm good with that.Thanks a lot.
Loaded....Thanks for trying.I appreciate that.
Quote from: vinnietbird;310096
I could not possibly let you get by without matching the turn and wiper levers... The shame of even thinking of doing so! LOL!
I will NOT argue with that.LOL.
