Topic: Running Issues SOLVED!!! (Read 4952 times) previous topic - next topic
to start off with, this is the new 87 TC.  the car starts and runs fine but dies like its running out of fuel after about 4 blocks of driving and wont restart, if I let the car sit the cycle repeats.  I have replaced the fuel pump and fuel pressure regulator and inspected the injectors.  not really sure where to go from here,  I know I am going to be asked to pull codes, the car came with a code reader but I havent had a chance to get it figured out to pull codes.  has anyone had a problem like this before?  also can a bad O2 or bap sensor cause a problem like this?  the FP never dies and keeps pressure so I am assuming that the problem is somewhere around the injectors or related parts. also, what tells the injectors to fire?
First, check codes, secondly, remove the TFI module and have it tested. I'd be willing to bet you have a bad one. While you're at it, go to the salvage yard and pull the remote TFI setup from the first Ford product you find with one. Your new TFI will appreciate it.
If the TFI checks out good, then I'd suspect the PIP inside the distributor.
Pulling the codes will take all the guess work out of it, so pull the codes first.
I forgot to add that I also installed a new distributor and had the tfi tested and it checked out good.
did you have the tfi tested a few times to get it hot and it still passed?
i second on pulling codes.
I always check the codes. Even when I don't think there's a problem, I'll still check the computer as regular maintenance  every couple months.
they tested the tfi I few times, how many would you reccomend? I have another TFI that I could try on it that I know is good.
Just because you installed a new/remaned distributor doesn't mean the PIP is good. Seen it happen before.
Pull codes first. Until then, everything is just a guess.
yes, but this distributor is doing the same thing the old one was doing. working on trying to pull codes...
well I am unable to pull codes with my code reader for some odd reason...  is there another way that I can do this?
here, look under the computer section on the left.
http://www.therangerstation.com/tech_library/index.php
all you need is a paper clip and either a test light, or the check engine light.
Quote from: Haystack;309692
I use a cut piece of sheet metal the width if the connector slots to plug them together. It always stays in  my tool chest in a separate little box. I have to use my buttstuffog meter to see the pulses, as the check light doesn't flash codes in my cougars. (it did in my 88 E-250 though). I really should get a light to do this one day, and make it easier to count.
I will see about getting an buttstuffog meter today, and try this.  am I going to be watching for the sweeps?  is that how I decipher the codes?
check the ineria switch, they will start to go bad and kill the FP and then cool down and the FP will work again....
I had this issue on a 85TC I had once,,,,,
