Topic: New guy...sort of (Read 2981 times) previous topic - next topic
New guy...sort of
Hello and welcome!! Sounds like you're going to have alot of fun with your Bird. It's going to look sharp once painted, the big and little wheel combo looks cool. I'm sure there's quite a few of us on here can help you out with some parts. Defenately check out the for sale section.
New guy...sort of
Welcome aboard, NICE bunch of people here !!!!............and you gotsa keep us up to date with your new project at all times
New guy...sort of
Quote from: 1 BADBIRD;309026
You got a good starting point .Lets get some paint on her and see what she can do . :burnout:
That's what I'm talking 'bout !!!:cheers: Trying to decide on a color and researching nitrous right now, and traction control. When the strip opens I'll be ready.
88 Sport ,306 roller block, flat tops, ARP rods and bolts, Compcam 533 lift/ 270 duration, roller rockers, ported 351w heads with 1.94 - 1.60 valves, 550 springs, 600cfm carb , full length headers, 2.5" dual X-pipe exhaust, MSD ignition, Hughes built C4, Weld Draglites, Tracloc /Richmond 3:73's
