Topic: i think i found my hood!!! (Read 4990 times) previous topic - next topic
Quote from: pegasus;308305
the engine in it now is a 302 with a e-cam and 1.7 roller rockers and some ported E7s Im using a C4 with a 3000-3500 tci converter on a step 2 with roll control the rear end in a ford 9in with 4:56 the int is stripped. it ran 12.90's in a 3350 lb car on street ET's w3.55's
sitting in the shop is 351W with 69 heads and a cardbord box full of goodies from ohio crankshaft that i bought from a puppies shop. and a oil filled coffee can full of frpp 1.6 roller rockers and a dual shot cheater Kit also picked up used
I have about 1,000 in the 351 but it still needs to hit the machine shop
Nice!
cowls belong on a chevrolet and nothing else.
While I don't' particularly car for that hood on a Cougarbird, I disagree with the above quoted statement....
Quote from: 1Bad88tbird;308268
I got mine from them as well, only it was thier other site, usbody.com . Mine is the Dominater 3" cowl. It's a nice hood but mine took a good bit of work to get it right.
Yeah, mine too! Mine came cracked and in such bad shape I had the guy refund me $350 and I fixed it myself, but you are dead on it took A LOT of work to get looking good.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Quote from: Romeo2k;308213
They should make the GT-41 Style for our cars.
I agree. I like that hood. But I may settle for a stock style with something added to it. :evilgrin:
I also want to get the glass trunk lid.
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
details on the car, looks intresting whats under the hood???
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: 347Thunder;309232
Hey 347Thunder , there is a aluminum headed 466 under the hood ,Check me out in the users rides . I,m sure you will like what you see !:headbang:
Love that hood 1 Badbird.
:burnout:
WTBEEP!!!!!!!!!!!  that is one bad bitch but it looks like you are twisting that thing like a pretzel
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
It's like a soul patch for the front of your car.  I'll give you a $1.00 to paint it that way.
Quote from: 347Thunder;309262
Thanks man it is pretty bad ! Its not really twisting if you watch the video . I have subframe connectors welded in . There is also an air bag in the right side coil that I need to put about 2 or 3 more lbs in . She runs real straight off the line .
I also have eibach springs all around and maximum motorsport control arms in the rear and the list goes on .
Quote from: 1 BADBIRD;309164
How bout my hood , check it out . The scoops were grafted in !
thats the type i will have on my 95
Very nice pass!  My wife would like that color a lot more; she complains that there are too many all black cars and it hard to tell when mine comes up for a run.
TED
Quote from: Cad-T-Bird 500;309407
TED
Yeah she really stands out , You either love it or hate it ! I love it !
