Topic: New Guy and Ride Here (Read 6961 times) previous topic - next topic
Quote from: 347Thunder;309265
Make me a photobucket:D with pictures of the cage:bowdown:
OK 347Thunder , I will see what I can do ! I need to take a few more and then I will send them to you .
By the way I used to go to Jensen beach every year for about the last 13 years . My wife had a great aunt that lived there right by the Rio Arch by Langford park .
[/IMG]
[/IMG]
I wish I had enough dough to throw at a car like that.  Maybe someday.
what's up with your mph did you run out of gear?
Killer vid
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Quote from: 347Thunder;309343
Killer vid
I get out of the hole real good . I pull a 1.5 60 ft , But it seems like I lose a little on the top end . My best pass was 11.50 at 115 mph . I will see what I will run this spring !:burnout:
what gear do you have and are you running out of fuel at the end? I ran a 12.0@115 but my 60' was a depressing 1.78 but now with 4.33 that thing will really launch.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: 347Thunder;309364
Im running 410s with a 1050 dominator with 92 jets in all 4 corners . Also running a mallory fuel pump with 8 psi of fuel pressure . I am definately not running out of gas .
maybe not enough cam??
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
