Topic: More vibration issues..... (Read 19776 times) previous topic - next topic
Quote from: 50tbrd88;307441
I have adjustable CHE upper control arms and have adjusted the pinion angle perfectly and still have the vibration (although it helped).  The way it sounds, I think we are having the same issue...
I also totally rebuilt the 8.8 after I swapped it in because of this vibration.  I installed a new carrier and all new bearings and still vibrates.  I am leaning towards 1.) driveshaft 2.) bent axle
What angle did you set it to? I have adjustable to.
I haven't had the time to find the sweet spot yet.
Right now it's set at -2 with the clamp on it. forgot to take it off when I did it. but it's better.
How do you check the axles for straightness....meaning,what's the best way?
It's highly, unliklely that you got 2 bent rears that have a bent axle! But if you want pull them , then check them with a long strait edge.
Should of got a Kat,  It's a joke bubba.
Quote from: Kitz Kat;307457
Ha Ha Kitz.....I'd laugh more,but all of this vibration stuff really has me thinking deeply.It's really bugging me.I'd like to get the Sport over 55 mph without issues.Maybe the bushing in the tail shaft of the T-5 is bad.I don't know.
You had it with the AOD to remember?' there is is one thing the same the DS. Need I say more? How you fix it is up to you, you could try the hose clamp thing to get you bye for now.
Have you had the stock shaft balanced yet? Was it a good balance?
Quote from: Kitz Kat;307445
If I remember I set somewhere between -2 and -3.  I have it written down out in the shop.  It took some trial and error to get it right.
Something I have always wondered about is if the vibration is because of the fact that I have my stock driveshaft bolted to a different rearend.  I makes me wonder if I unbolted the yoke from the diff and rotated it around say 180 degrees then bolted it back up, if the vibration would change?  Vin have you tried this?  I assume if this is the problem a good driveline place could get it balanced.
Reply #39
I haven't tried it,but I will.When I take my Crown Vic driveshaft up to Ok. City to have it done,it may make all the difference,but time is holding me back right now.
As far as the same driveshaft,the one I'm using now I've only had for a couple of months.Same issue.Although,the vibration is worse with the 3.73 rear than with the 3.55 rear.I'm baffled. 88Turbo is supposed to be sending me the front yoke with the vibration damper on it.Maybe that'll help a little with new u-joints and the clamp idea from Kitz until I can get the aluminum shaft done up for the Sport.I'll make some calls Monday morning.
Reply #40
refer to my theory in your other thread....
Reply #41
I didn't swap them,but I did look them over REALLY closely and they looked great.I am staring to feel strongly about the drive shaft not liking the lower gears.
Reply #42
did you try what i had mentioned yet?
1979 Ford Fairmont
[/B]
Reply #43
Quote from: 32VFoxBird;307311
Jack the rear up, pull the driveshaft off, then run the car up to 60+mph. that'll rule out the DS, rearend, or tires.
I'm going to do that Monday morning when the sun comes up.It won't take but a few minutes to pull the driveshaft.I'll put the car on the jack stands,chock the wheels and run it.I'll let you know what happens.
By the way....good idea.
Reply #44
Alright,I just got off the phone with the drive shaft guys....$108.00 to shorten,balance the aluminum Crown Vic drive shaft,and install adapter u-joints for my car's yoke and such..Hello aluminum drive shaft.I'll try to get everything up there this week for them.While I'm there I'm going to try to hit a couple of new yards.
