Topic: Made some progress...... (Read 6920 times) previous topic - next topic
What about the differential bearings,axle and carrier?
Thunderjet302 had a bent axle once, he said he had a vibration from it...might look into that, too.
Just a thought, We all lower are cars, Lowering it is not changing the height of anything except the body, The engine is still in the same spot, and tranny. unless the k frame was changed. I have the same vibe, not serious, but there. I put it toward stiffining the body up. It is annoying because you think it shouldn't do it.
I have CW mounts, they give a little vibe by themselves. Your best bet is to get the driveline balanced, then go from there. I haven't done that yet because I use the hose clamp trick for now and it made a big difference. I had the vibe with the AOD and the t-5, You need to eliminate the shaft as a problem, since your already missing parts of it.
I'm swapping the u-joints in the extra shaft and reinstalling it.I'll grab a big clamp while I'm there.
How many do you plan on changing? If there not rusted or loose don't waste your time, seriously.
They are a little loose.It won't take 30 minutes from start to finish (other than getting the u-joints).I got nothing to lose.
Hey Kitz,respond to the drive train section on vibration.This thread needs to be closed.It's getting technical in a non tech area.
Oh moderators....close this please.Lock it.
Leave it open, just in case.
O.K.,if Kitz says so.LOL.
Reply #39
Does not pinion angle change when lowering a vehicle?
Reply #40
Vinnie, does it vibe if you coast? (not in gear)
Reply #41
Quote from: FordTruckFreeek;307415
Yeah I had a bent passenger side axle shaft. I have no idea how that happened either. It vibrated like crazy above 65 mph and the axle was ever so barely bent. It was a beotch to get out too. That  thing was stuck in the bearing because it was bent.
Reply #42
My axles slide in or out of the differential easily.I'll check the old ones first.The replacement axles had no issues in or out either.Still,maybe there's a small bend,but what are the ods of bent axles in two diffs?
Yes,once the vibration starts at around 55,it vibrates in any gear,neutral,it doesn't matter....just over 55mph.
Reply #43
Quote from: vinnietbird;307535
Odds can be pretty good if it's the rear pass side. A lot of people clip curbs by accident when turning corners. I do it all the time in my van. by accident of course.
Thunderjet's was also the pass. side
Reply #44
Just for fun take the driver's side axle from the other rear and swap it into the passenger side rear on the car. See if it still vibrates.
