Topic: Go fast goodies (Read 2268 times) previous topic - next topic
Go fast goodies
These are mustang 1-3/4 hooker super comp I just got them back from the coaters today. I got them from a guy on ebay shipped for $275(new). then coating was $250. both equal less then the painted ones cost new $580. I cant wait to put them on tomorrow.
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Go fast goodies
Wow.....those are pretty.Too pretty to use.Can't you hang them in the living room and just look at them?
Go fast goodies
Nope, I just finished bolting them up but now I need to cut out the tranny crossmember  and make a new one so I can run lers. The end of the collectors is almost hitting the crossmember how stupid is that
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Go fast goodies
Get to cutting,and pics when you're done.Again,those are sweet.I've thought about long tubes,but just can't bring myself to do it.
Go fast goodies
Got any pics yet??????  Them there things are PRETTY !!!!
Go fast goodies
still wating to get my exhaust done before I make my mount but this is what I got
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Go fast goodies
Looks great.
Mike
Go fast goodies
Your car is the tits man.  Nice work all around!!
Go fast goodies
well just finished making the cross member now I need to make tabs on the frame rail to mount this bad boy and then I can get my exhaust done (personally I like driving it with open headers).
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Go fast goodies
That's what you call squeezing them in there. Nice job they look good.
Go fast goodies
so this is what I ended up with, a problem that I did not see before is that the  thing sits 3-1/4 in from the ground. Once I get my exhaust done I will try to fix it but I just needed something to hold the tranny since I cut the factory brackets off.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Go fast goodies
some more
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Go fast goodies
wow that sits way too low for my comfort. But i got to hand it to ya with the fab skills. One thing i saw would there be a way to angle the cut outs for the exhaust up insted of down for clearance?
Got that fox rash again!
-Resident smartass! :ies:
Go fast goodies
I will try to fix it after I get my exhaust hung then I will see how much room I have I needed to make this so I could remove the factory mounts. But I agree it is way to low for me also good thing I bought extra tubing
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
