Topic: A lot of parts need a new home...... (Read 7095 times) previous topic - next topic
Quote from: supercharged88;305071
Dibs on door cup inserts pics? nieasquidward@yahoo.com
Pic sent
New stuff added.........CHECK IT !!!
Keys added...Thinning out my stuff.
Quote from: vinnietbird;304807
Fordguy,thanks a lot.
your welcome, thanks man.
86 thunderbird elan
86 mustang coupe
PM's answered.
more stuff.
more......again.......
88 Turbo Coupe fuel pump assembly...........Does it come with the float?
86 TC.......Intake, fmic ,bov ,pillar gauges......more to come
Yes,the assembly.Pump and housing.The float,meaning the fuel gauge sender,is separate,but we can make a deal.
smack it up there.
Reply #39
Got a timing chain cover in there? one of the water pump bolts snapped off in the cover
Reply #40
Nope,not until I pull this current engine.Use some PB Blaster and soak the bolt,then use a hammer and punch and drive it out.That's a fairly common problem.I took my timing cover down and had it bead blasted,then painted it engine color.Try my idea,it'll probably work for you.I do believe I'm going to start gathering up front covers every chance I get.
Reply #41
The threads snapped off inside the cover (the top bolt/stud) I'd have to drill it out. it maybe time for a new one.
Reply #42
Oh,the threaded part.I was thinking lower in the cover.Can it be soaked and then use an easy out?I'll look around anyway and see what I can find for you.No promises,but I'll do my best.
Reply #43
I'll will try the easy out first. but it's pretty corroded in there. I'll start soaking it tomorrow
Reply #44
Let it soak pretty good for 24 hours if it's really bad.That stuff is good for these things.
