Topic: 5.0 Badges are back (Read 5458 times) previous topic - next topic
5.0 Badges are back
I call dibs on being the 1st one to put the new style 5.0 badges on their fox T-bird.  lol.
On a side note: I guess I will have to wait for some kid to wreck their old 2011 5.0 in the year 2021 and drop that motor into my '07.  Sucks for me that mine is 300 hp and now the V6 will eclipse that!!
5.0 Badges are back
do we know the bell housing pattern?  same traditional 5.0? my diggin around says yes but not sure if i am right.
5.0 Badges are back
Gone is the Tremec 5-speed transmission and stepping up to the plate is a new Ford/Getrag MT82 6-speed close ratio manual transmission.  Gear ratios are: 3.66, 2.43, 1.69, 1.32, 1.00 and 0.65 for sixth.  Final drive ratio for manual cars is 3.31:1 but optional ratios will be available. A 6R80 6-speed automatic can also be ordered with: 4.17, 2.34, 1.52, 1.14, .87 and .69 gear ratios.  Automatic equipped vehicles get a 3.15:1 rear gear.
Very interesting gear ratios.
An optional Brembo brake package is also available which will include 14” front rotors and 4-piston Brembo calipers borrowed from the GT-500.
Nice.
Nestled between the strut towers is a new 5.0L (4,952cc / 302 ci) aluminum block capped by new compact 4-valve aluminum heads with Twin Independent-Variable Cam Timing. Compression is a lofty 11:1 which provides 405 horsepower on regular pump gas and 412 horsepower on premium. On premium or pump gas, however, the 2011 Mustang GT should still get at least a 25 MPG EPA rating.
The new 5.0L engine is an all aluminum block, ribbed for strength and durability. It has been tested well beyond the published horsepower figures. Nodular iron main bearing caps with 4 bolts and cross bolts help to keep the fully counterweighted forged steel crank in place. High strength forged powdered metal rods with floating pins keep the hypereutectic pistons in place. Oil squirters spray oil on the underside of the piston crown keeping it cool, and allow lots of ignition timing to be added.
But we knew it was going to get budget rods and pistons anyway. The previous NA 4.6 rods cost ford around 7 dollars each where as the ones in the terminator were in the 50s. That would add up fast. That, and production numbers will be much higher than the terminator project i assume. The CR is high, but with the wideband the car will have and the new oil spray patten that sprays the underside of the piston, hopefully boost will still be safely manageable.
Another great addition are specially tuned headers. According Mike Harrison, 5.0L Chief Engineer, “Every Mustang owner throws away the header. So we’re going to give them the headers they always wanted without needing buy aftermarket headers.” The headers provide significant torque at low speed because the pulses from the exhaust are separated from each other so there is no interference between exhaust events to interrupt the airflow. Only long tube headers will out perform the factory pieces.
Sweetness.
~John~
5.0 Badges are back
Where are my pushrods? ;)
5.0 Badges are back
In the trash can where they belong.:poke:
~John~
5.0 Badges are back
Are they stainless?
5.0 Badges are back
Are they stainless?
I think so. They aren't cast, that's for sure.
~John~
5.0 Badges are back
So far the thing that i really don't care for is that it looks like it runs a timing belt setup.
~John~
5.0 Badges are back
Do you honestly think Ford would do that after running a chain belt for so long on the 4.6?
5.0 Badges are back
Yes, I wouldn't be surprised at all....
~John~
5.0 Badges are back
ford has really raised the bar, kinda kills my motivation on a pushrod motor anymore
seek, did you get a shot anywhere of the bell housing pattern?
5.0 Badges are back
Kinda lame that they would go to a belt like that...
