Topic: head gasket replacement (Read 2753 times) previous topic - next topic
Bump
Bump -
Anyone have any suggestions...
1987 Ford Thunderbird Base model 3.8l  Bone stock.  Trying to get it to perform the best it can.  Wanted:  Nice set of 4 bolt wheels.
Since I got no feedback, I figured I will take the heads off and have them resurfaced.  Install all new gaskets and hope for the best.
Trying to play it safe, I guess.
hey bigherm
i didnt fix my yet well i kinda have. i used some stuff  liquid stuff called steel seal.
and it worked for about 2,000 miles and then the leaking came back. so  i dumped another bottle in and that helped for another 1,500. the second bottle didnt work as well, so i tried another brand called blue devil. i cant replace the head gasket right now as i have my 1995 towncar in pulled apart for the same problem , though i am hoping its just the intake manifold gasket on the towncar.  a few weeks ago i changed the plugs on the car and the left side plugs were all wet and the right side plugs were not. so  hopefully this liquid stuff will work till i can get the job done the right way. anyway good luck with yours .
eddie
my rides well some of them work:hick:
1995 towncar in black 246 K non running
1989 continental 110K waiting for a part
1984 cougar head gaskets done almost ready!
Yikes the daily ride ...1998 chevy lumina:hick:
FWIW:
I'm the original owner of a 1984, 3.8L cougar.
Had a high end rebuilder rebuild the engine (about 3000 miles ago).-- big $$.
Head gaskets major issue on the 3.8.
Tend to crack by the lower head bolts because of lack of radius on the heads.
Crack appears to open up once engine heats up, but crack doesn't show under testing.
Rebuilder initially used standard Ford gaskets, then tried MLS.  Still had issues.
Finally went with "Irontite" -- composite ceramic -- and sealed the
MLS from the inside coolant channel..
Whether will hold -- jury still out.
Low oil pressure also a problem after rebuild.
"Rebuilder" magazine has an article on how to prevent.
If you go ahead and redo, would also look at whether or not you can
swap Cams and go with a roller bearing instead of back with the
flat tappet cam.  Wish I had known about this, as flat tappet requires
more ZDDP in the oil -- most oils no longer have the 1200-1500 PPM required
and additives are expensive.    COMP Cams had a lot of cam failures
because of this -- lack of ZDDP.
There is one rebuilder -- Toronto Canada - that supposedly specializes in the 3.8L and
races these engines.  Don't recall name off hand, never used him, but based on web info
appears to know what he's doing.
Hope above helps.
Quote from: blackcat85;315282
hey bigherm
Yeah, I am kind of in the same boat I have another car tore apart and I am trying to get one of them done.  But I always seem to be running out of time.  I will look into the products you mentioned.  Good luck.
Quote from: dw85745;316385
FWIW:
Hope above helps.
I have been kicking the idea around of putting 351W in the car instead of rebuilding the 3.8.
As far as oil with ZDDP, I have been using the Napa Premium 15W40.  It is their fleet services oil and still has adequate zddp levels.
Thanks for the info.
351W is the way I'd go after all the hassle with the 3.8.
 Interesting on NAPA.  I think will still have one outlet locally.
I know Shell Rotella still has higher ZDDP (around 1200), but that also is supposed to change and go lower.
This is an continuing ongoing issue as the oil manufacturers are continually changing their mix.    Spent a lot of time with this issue.    For example oil grading (SJ, SL, SM) has NOTHING to do with it.  This is considered and additive so doesn't fall under grading standard.
You can get some racing oils with higher ZDDP but big $$$.
3.8's are known to blow head gaskets, It's not a mystery. If you replace them you can get a long time before it happens again. Make sure it wasn't warped , and install a good name gasket. Sometimes the intake leaks and everybody says the head. That's negotiable , because when you replace the head gaskets you  will replace the intake gasket. A compression check can usually find the difference. Worst case it can be a cracked head , then you put it back together and never know what happened.
