Topic: Unique Repair of bad heater core (Read 3824 times) previous topic - next topic
You will have full blast heat all the time.
The temperature blend door only controls how much air goes through the heater core and how much bypasses it.
All of the air goes through the evaporator core.
Quote from: softtouch;302121
Very funny.  I suppose your blue and red would then be backwards in the winter
think about it guys the a/c core will handle the hot temps. if u think im wrong look at a heat pump system on a house even though its not antifreeze it does reverse the flow of the refrigant to heat ur house making the a-coil go from a cooling to heating coil . only they are made to handle high pressures . so the a/c core should out last the heater core. heater core made of copper , a/c core made of aluminum.so it should stand up better to corrosion alot better.but hell ive been wrong before. lol
Yes but assuming the "heat" blend door would passing cold air due to the heater core being disconnected, there would still be control of the air temp...
Also could install a in line valve to control the flow of coolant through the evap...
Quote from: TurboCoupe50;302161
Manual control only.  Auto would drive the door in the wrong direction.
I used this trick as a "temporary" fix.  It got me through 3 winters.  The only down side was the heat was either on or off.  During the summer, I just used a metal coupler and bypassed the evaporator until I needed it again the next winter.  Temporary could have easily become permanent if I had a way to control temperature.  In 3 years it never failed to bring me toasty-warm heat.
1987 Thunderbird 3.8. Sold :(
Quote from: xjeffs;302231
Yeah I tend to forget about the EATC systems, especially since I tend to avoid them...
The air goes through the evaporator core first and will be heated before it gets to the blend door/ heater core.
Quote from: 84TBirdTurbo42;302013
i was just wondering of the corrosiveness with antifreeze thats all
Most newer antifreeze has additives, to keep all the aluminum in the newer motors safe. So I would assume the core would be reasonably safe.:D
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
I did this to my white coug several years ago and posted it on the old board.
only one problem,,,,,,,, YOU HAVE HEAT!!!
not only do you have heat but you have it on vertually every setting except off.
I dont care though, it solved my problem.
Does it increase the intensity of the air? The setup in my car (stock) doesn't do a whole lot, and I might try this to incease the heat. It takes forever for the car to warm up, and its either sweat buckets or freeze your stones off, and I can't understand it.
your just gonna have to take the blower motor out and clean it,, check the duct work, check for kinds in the flex hose ect.  my blower is great,, perhaps your burshes on the motor itself are getting worn and its speed is slower ,,although you would likely blown the on board fuse at teh resistor block.
Your car warming up has very little if anything to do with the heater core.
It's good advice, when my taurus had a transmission overheat issue I started using my a/c condensor for a transmission cooler. Worked like a charm!
