Topic: Integrated Voltage Regulator in the dash (Read 7056 times) previous topic - next topic
i would venture to say the small winding in there could be observed as a possible shunt resource. should power this up and see what i get.
problem is i dont know what my baseline milivolt would be although i would know the mv drop, nor what ampacity the possible shunt would be.
i have often wanted to fab up a shunt for our cars, its such a simple concept, i deal with them all the time.
im not saying its a shunt,, just its possible it might be one by default.
The oil pres sender is one item i dont have documented in my diy,,, may take time tomorrow to get that for you.  Since i have a full digi cluster, the oil data is coming from there so now i have to figure out where its at.
manual 33 05  35  test point TS3 says the resistivity of the "sender" should maintain a resistive value between 9 and 40 ohms while reving the motor a little back and forth.
I was actually interested in finding out what primary piece part manages the oil bar graph and did not find my answer.  Apparently the sender does.
I found no hint of a sensor though.
Quote from: jcassity;296951
Do you think the bar graph in full digital dash? I think it should work like an electronic EVmeter - it reads voltage on some resistor and compares it with values for low and high pressure, so the pressure sender could be same as for buttstuffog dash.
Quote from: Trinom;296967
You think the bar graph in full digital dash?
is that a question?
I was just commenting on the full digital cluster.
The other options on our cars is a single oil light.  In this case, the oil sending unit is just an "on" or "off" switch and nothing more.
Sorry, my mistake. Edited.
Yes, I know about all 3 options. If the change of IVR won't take effect I'm going to make half digital dash by myself with microprocessor and small LCD.
So, I was yesterday in the garrage and was trying to measure resistances of senders. Unfortunately, I couldn't start the engine, because I have the battery in another car, so I have some numbers from staying car.
oil pressure sender ... > 200 Ohms*
temperature sender ... > 200 Ohms*
fuel amount sender ... 36,5 Ohms
*out of 200 Ohm range - I didn't remember the exact positions of each sender contact and didn't try higher ranges, because there were a lot of lower numbers
I think, that there must be some fault, because resistances over 100 ohms are out of ranges. Or not?
Here are all numbers I measured. Dash means resistance over 200 Ohms.
-....-....12,4...3,6...3,6...36,5.....-......-.......4,9
-...8,8...2,6.....3......3.....3,5....5,3...2,6....197,8
And finaly, I decided to open the IVR. It didn't do anything until I loosened the small screw. It didn't have enough force to bend the bimetal, so the contacts were still connected. Here are some photos:
very good pics man,, nice work on the replacement parts.
whatcha got there for parts?
Quote from: jcassity;307521
I'm not definately sure if you're asking for the price or components, so I'll write both.
78S05 (5V stabilizer, up to 2A)
two capacitors (10 uF and 100 nF)
couple of wires, some bolt and two nuts
So complete repair cost me 15 Czech Crowns (it's little bit less than one dollar) :)
Hey Gang,
I havn't gotten around to my V6-V8 swap yet,still building the engine and tranny ect.
My digital dash V6,87 Bird has a temp guage that's inop,no check engine light but car seems to run rough and rich,made me think it may be the temp sensor? Well I tried a new one along w/a tested T-stat and still nothing.
Any ideas?  I'm not an electronics guru. Have the basic understandings but any ideas are welcome.
Hey Guys Just for an update.
This is sold on ebay for 20 dollars and it comes with no hassle warranty.
item number 270595341050
[/IMG]
[/IMG]
Yup, I saw that too and ordered one.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
