Topic: Fresh engine won't start. (Read 2818 times) previous topic - next topic
I'd guess cam timing or too tight valve adjustment... Piston rings with the gaps lined up would not cause the problem of NO compression... Would probably have a bit of blowby and get worse with time, but it'd no doubt have plenty of compression to run...
