Topic: question about sway bar links.......... (Read 1793 times) previous topic - next topic
I bought a set of sway bars for my car, The install kit came with two size tubes for the link height, a 4.5 inch and a 3.5 inch. What size would work best for my application. Since I lowered the car I noticed that the front tires run against the sway bar. I am thinking that the links are to high and pushing the bar up and out towards the tires.
Re: question about sway bar links..........
Use the tubes that will position the ends of the sway bar level with the ground.  When I lowered my 'Bird, I had to fabricate the end links because I couldn't find a link of the correct length.
