Topic: subframe connectors (Read 4585 times) previous topic - next topic
subframe connectors
I never melted mine, but did accidentally ground a hole in one prepping to weld.
subframe connectors
the way i really want to do it is completely different from any i have ever seen. i want to use 2x3 tubing and notch the floor and weld full length. this way it will not hang down any lower that the stock subframes. i dont think i will end up doing them this way, but we shall see.
i know 2x3 overkill, but i do have BIG plans for the drivetrain in this car and dont want any possibility of things flexing.......
86 Mustang GT
subframe connectors
The way mine are are simple and it creates a box so it's very strong.  But it does hang down a bit, on may car it has not been a problem and never hit but if you went way lower it might.  The real way to reduce all flex is the roll cage.
TED
subframe connectors
it will have a rollbar eventually
86 Mustang GT
subframe connectors
search for gumby's SFC thread. He used 2x3 through the floor
subframe connectors
I used 2X2 .083 square tubing upper/ 1X2 .083 tubing for the lower in mine and I put various plates connecting the rear subframe to the bulk head. Also put in a bulkhead plate for the 2 square to butt up against. Even with the IRS in, I can jack up any corner and lift 3 tires off the ground  :D
86' T/C 4.6L DOHC
16' Chebby Cruze 1.4L Turbo
“Heavy Metal Mistress”
[/COLOR][/SIZE]
subframe connectors
Quote from: Dougy_Fresh;293568
you havent looked hard enough. ;)
http://www.foxtbirdcougarforums.com/showthread.php?t=13523
i know 2x3 overkill
not from where im sitting.
subframe connectors
1x2 heavy wall square tubing here. It is a little low but it's great for running battery cables, vacuum lines, methanol lines, etc. thru.
My car's best 60' is 1.55 so I know they are doing their job.
TC#1- 2.5T- 10.14@134....9.76@138 with a 50shot
TC#2- Turbo BBF project
TC#3- parts car
subframe connectors
the mustang shell i got has 1x2 tubing and i chuckle every time i think about using that size for the t-bird....my power goals would most likely make 1x2 twist like a pretzel.....
my plan for doing this will put my connectors no lower than the stock subframes
86 Mustang GT
subframe connectors
Quote from: Pressure cooked chicken;295395
Holy hell! what rock did you crawl out from under?
SFC on the SHO are 1x2 IIRC and they make a world of difference. I lift wheels all the time. Different platform but still a unibody, and as far as im concerned "overkill" is far from anything you will do with your SFC.
