Topic: Stock 1987 HO cam (Read 1216 times) previous topic - next topic
Stock 1987 HO cam
I've got the HO computer and 19# injectors on order, but scoring a stock HO cam is proving to be difficult. I've been searching the forums for a few hours and I'm going to take the advice to not run anything more radical than a bone-stock cam with a SD setup. It's going in my 1987 motor, so I presume that I need a cam for hydraulic roller lifters (true? can I use my existing lifters?) Anyhow, I'm hoping that the cam is the last piece that I need.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Stock 1987 HO cam
Try the corral.net for the cam and I would replace the lifters. Years ago I had to pull my motor apart to replace a bad lifter and it really sucked because I had the motor apart a couple months before that.
Stock 1987 HO cam
You can use the existing lifters and rockers.Just swap the cam.I have one for sale,but it goes as a set with the computer and injectors.Did you check Ebay and the Corral?
Stock 1987 HO cam
Thanks for the tip, Vin! I went and posted on the corral forums. eBay came up empty, I've been searching for hours.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Stock 1987 HO cam
I have one i'll let go for 40+ shipping if your interested.
Came out of my 91HO engine with 100 000km's.
It's in mint condition,the only reason i swapped it out is because i went to a trickflow stage1.
If you have an 86-88+ 5.0L then it already has the roller lifters which you can reuse.
If it has flat tappets then you must change the lifters.
Stock 1987 HO cam
Sounds fine to me :D It would be going in my '87. Do you want to PM me when you have a total? My ZIP is 19015.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
Stock 1987 HO cam
I'll get ya a total for tommorow evening for canada post ground shipping to the usa.
Stock 1987 HO cam
the 91-93 cats and birds with a 5.0 used the 93 cobra spec cam...
Stock 1987 HO cam
http://cgi.ebay.com/ebaymotors/5-0-mustang-camshaft_W0QQcmdZViewItemQQ_trksidZp3286Q2ec0Q2em14QQhashZitem2c50f8e02eQQitemZ190337048622QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Stock 1987 HO cam
Quote from: Haystack;292546
Im a little uninformed about the 93 cobra cam, what is the difference from the HO?
Mike
Stock 1987 HO cam
I've always heard the H.O cam actually had more low end than the Cobra cam....BUT,the Cobra had 1.7 roller rockers and GT 40 heads.
Stock 1987 HO cam
the 93 cobra had better parts like vinnie said. Also, the 91-93 cars had a cruddier intake and the lower rating for HP that year then the mustang. The 94-95 mustangs had the same intake with a few better parts, but only made 10 hp more and used the regular H.O. cam from my reading. I really think the cobra cam is slightly better and its alot easier to find a 91-93 cat/bird then a mustang around here.
Stock 1987 HO cam
The Cobra spec cam is more of a torque cam...Ford's way of keeping the freer breathing '93-'95 Cobra engine a nice all around performer.  That cam worked out nicely in the MN-12 cougars/birds because it traded a little top end HP for low end torque.  Not ALL MN-12 5.0's came with the cobra-spec cam, some were equipped with the good ol' HO cam.
