Topic: 1998 Explorer engine questions..... (Read 7511 times) previous topic - next topic
I've got GT40Ps on my car, with 1.7RRs. I'm using a set of BBK Shorty headers. Same typical set a lot of 5.0 owners use, Only problem is you need a right angle boot on the #7 cylinder, and that plug needs to be installed before the header gets bolted on, otherwise you won't get a tool in there. Every other cylinder should be no problem at all. I also run the stock HO cam and have completely eliminated the EGR and Smog. I've got one little hickup that randomly shows its face but its nothing to complain about, generally the car runs great. I believe my problem comes from a stock ECU trying to run a motor thats drastically changed. (Speed Density that is). I haven't found a Mass Air ECU yet.  I'm also running 24# injectors, Its diffenently a wise choice for the combo. All in all, my car runs great and I'm running basically what you have described. Good luck.
Are you putting the GT40Ps on the block you have now with the flat tops? You probably will have some piston to valve issues if you run the GT40Ps and an E303 with the flat tops as the GT40Ps have bigger intake valves.
Quote from: thunderjet302;291188
I'm buying the entire engine.
Quote from: Xtremitie;291177
I have Mass Air,so,I shouldn't have any issues with it at all.
Quote from: vinnietbird;291192
Ok just making sure ;)
Quote from: thunderjet302;291194
I'll take any comments.Whether it's "making sure" stuff,hints and tips,whatever.I appreciate it all.
Since you have time to build the engine right (you have a running T-bird ;)) I suggest saving your money up and doing it right. Rebuild the lower end and heads with quality components, not cheap stuff. For a cam contact Jay here: http://www.camshaftinnovations.com/ I wish I did when I built my engine. He can hook you up with a matched cam, lifters, springs, and timing chain. Yes it will cost more than it would from ebay or Summit Racing but you get top quality parts. It's cheaper to buy something once than twice ;)
The bottom end....short block....is in great shape.Only 30,xxx miles on it.No rebuild for it.The heads will get a mild posting,valve job,new valve seals and springs.When I install the heads back on to the block,I'll install my 1.6 roller rockers more than likely and my E303.That's as of this thread.Things can change over time.I'm taking it one step at a time.No rush.
Here's a pic of my explorer long block when I first bought the car.
Was it a "P" engine?
Quote from: vinnietbird;291356
Yes it was.
It may have been said but I didn't see it..The 96/97 Explorer 302 had the internal EGR intake. 98-2000 had the ext.
You could probly just get a 96/97 intake and be fine with the same heads.
1988 Cougar LS 5.0 (currently parting out):cougarsmily:
1989 Mustang LX Notch 2.3 (Project):ford:
He's already got an Explorer intake on his current engine that can be used. The heads are all drilled for EGR as far as I know. Mine (gt40p's from I think 2000?) has functional EGR.
1988 Thunderbird Sport
Yep,I'm using the '96 Explorer intake on the replacement engine.....when the time comes.
Due to horrible weather,the engine has been postponed until Monday.Oh well,I can't use it right now anyway.
