Topic: Herky-Jerky (Read 2257 times) previous topic - next topic
Herky-Jerky
I have an A9L.  It drives pretty good with the 55mm but bucks pretty bad with the 70mm F2VF.
The A9L was supposed to hold me over till I finished designing my Plug-n-Play Megasquirt board.
Herky-Jerky
Adjusting the F/P helps but only for a little while... After a couple run cycles, the EEC will lean the A/F ratio back to stock... If you run enough F/P to exceed the EEC adaptive limit, it will be rich on cruse and lazy at full throttle...
You can try rotating the angle of the MAF, sometimes that will make a noticeable improvement...
