Topic: Fuel leak? (Read 1905 times) previous topic - next topic
Fuel leak?
:mad:I have a puddle of fuel between #2 and #3 injector. I had earlier changed all the "O" rings but that didn't stop the leak. I actually thought it was the #1 fuel injector. Nevertheless, I bought only (1) injector (I know, I usually get all four), but for the quick fix, I just bought one. Well I changed injector #2(that's were the leak looked like it was coming from) but that didn't help.
My question is, has anyone heard of that fuel rail that sits on the injectors leaking??
Or is it possible that there might be a crack in one of the bezels? BTW my car is a '88 Turbo 5spd.
Ride the Thunder & Feel the Power
Fuel leak?
Can´t you see the leak? When I was working in garage then I had few issues with fuel rail that sits on the injectors & is leaking the main problem was the o-ring between fuel rail & injector. Also once there was micro fracture in the fuel rail but then the leak was so big that you saw it like g.
Fuel leak?
Ive heard of the injector body's leaking.
Mike
Fuel leak?
Did you make  sure you pulled the old o-rings from the rail if any were left behind?Also,you may want to pull the rail off,make sure the o-rings on the injectors are all good,old pieces removed,and then lightly apply some engine oil on the o-rings before re-installing the injectors into the intake and the rails to the injectors.Then make sure that the rail is firmly seated on the injectors,and while holding the rail down,bolt it down.There is some adjustment to the rails.
Fuel leak?
Remove the upper intake, dry up any gas with a rag.  Then have someone cycle the key to on a few times. I had a bent injector cup leak the first time I put my new intake on.  I had to go cut a new fuel rail from the junkyard.
-Z
Fuel leak?
I guess my question is answered. I was wondering where I could get a "new" fuel rail. It looks like I might have to go looking in junkyards..... It looks 99.9% that the fuel rail might be the problem. (on the comical side, I dropped one the bolts that held the upper intake and oil dipstick in place. It was "absorbed" by "bermuda" T-Bird Triangle!! I'll never find it!!)
Fuel leak?
A 5.0 Mustang and Mark VII use the same rails.Check on the Corral.
Fuel leak?
Quote from: vinnietbird;290498
they use the same rails as a TC?  vinnie vinnie vinnie.....
if your needing a fuel rail I have 2 spares I could send one out cheap.
Fuel leak?
Hey "88turbo", I'll take on off your hand. Email me at thorpower1988@yahoo.com on total cost..
thx
Fuel leak?
I had a fuel rail crack once before.
Fuel leak?
Money sent!
