Topic: 85/86 t/c cluster pictures? (Read 1687 times) previous topic - next topic
anyone have one of these out that can take a good front and backside picture of an 85/86 t/c cluster.  trying ot get down to the nitty gritty of what the difference really is between 85, 86, 87 and 88.  if its just appearance or fit/function.
THANKS GUYS!
Mike
I didn't think there was a difference.
the only difference is in the boost guage, 85-86 show upto 24psi while 87-88 only show to 18psi
Edit: and the 87-88 have the ride control light.
so then really its "plug n play" to stick an 87/88 in an 85 t/c?  just trying to make total clarification before i purchase.
Mike
I don't have a TC, but swapped an 87 base cluster into my '86 base bird.  I would think if the dash wiring is the same on the base birds, then it would be the same on the TC's too.  I don't think much was changed from 86 to 87 other than outside cosmetics and addition of a 3rd tail lamp on each side.  This would have eliminated a little wiring on the front end, and added a little on the back end, but don't think the dash harness changed at all.
:birdsmily:
The guts inside the 85-86 tach are totally different than the 87-88.  And you can't convert the 85-86 tach to read a V8 pulse. Hence why I had to put an 85-86 face on a 87-88 tach when I wanted a boost gauge, no firm ride light to go with my V8 tachometer.
pro-five-oh
how do you convert the 87/88 for v8?
Mike
Coolcats.net has the info.
pro-five-oh
well, looks liek whioever did the v8 sawp on this bird also swapped the entire dash harness.  i has the dual plugs for the digital dash, doesnt look spliced in anywhere.  dotn know what i am going ot do now.  i dont think there is enough stretch in the wirs for the brown plug to re-pin the gray plug.  i may just re-pin the temp sensior lead and see if it makes the buttstuffog cluster gauge work.  if not, digital is staying in and its getting two gauges (temp and oil) in a pillar pod.  anyone know what pillar pod fits best?  how well does a mustang one fit?  just the pod, not the whole pillar with pods molded into it.
Mike
