Topic: Parting 86 TC with 5.0 H.O. swap To many new parrts to list!!!! (Read 3226 times) previous topic - next topic
I'm sorry the carb/intake are gone.....above is about all thats left....a few other odds and ends but thats about it.
updated list with a few more items
Rearends gone, Trannys gone, only major thing left besides body parts is the 5.0 HO motor with 60k miles and the QA1 k-member.....someone come buy these...I want them gone.
Do you still have the steering column? and if so, is it tight? Mine is loose.  How much?
1987 Cougar XR7 308 S/C
Trick Flow Heads/S-Trim/42lb. Inj./Stg. 1 cam/4.10 Detroit Locker,Yukon Axles,T/A Rear End Housing,CHE Upper Control Arms,Chucks Poly motor mounts,
Working A/C -- BBK Shorties/ H-Pipe/ Flowmasters/ Eibach Springs/SSM lift bars/ Max Motorsports subframe connectors/3300 stall convert/ etc....... list keeps going
Lots and Lots of Parts to make you go FAST !!
2008 Mustang GT - - Dark candy Apple Red
Roush Louvers;18" Polished Bullit Rim;3.55 Posi;Hood Scoop;Pypes Exhaust
growl sent you a pm ;)
