Topic: Hey I finally killed an AOD (Read 3512 times) previous topic - next topic
Man that sucks...but at least it didn't break on you in the spring.  Sounds like the buildup you have planned should really be an improvement.
I think AOD's are pretty good trannies.  Mine is dead stock with 180000+ on it and has never been touched other than regular fluid/filter changes.  Still shifts like it always did (now that I say that it will probably puke on me).  If and when it does puke, I will have to do some serious thinking about a 5 speed swap...but thats just me.
Quote from: 50tbrd88;289583
It was a no brainer for me. :hick:
Matt
Quote from: TurboCoupe50;289492
If you'd installed a shift kit when you did the engine mods, I'd bet it would still be fine...
I'm just gonna go ahead and agree with this one :D
Quote from: shame302;289461
Meh, Do a manual trans swap all ready....
X2, you definatly wont regret it if you enjoy driving the car at all....
Stock, my Super Coupe AOD slipped badly when I manually shifted it 6000, after the kit no slip at all... Over nine years later and probably 800 drag strip passes, it still does fairly good but isn't as firm as when I first installed the kit...
Quote from: V8Demon;289657
It might still be alive but I was just lazy and let it go. Now I'm going to pay for it but I'll have a better trans :hick:
Quote from: 1WLD BRD;289689
But the sleeper factor of a column shifter AOD car is just too much fun;)
If I did a manual trans swap it would have to be a T-56. Why bother with a breakage pr0ne T5. If I went with a T-56 swap it would probably cost more than the AOD replacement.
Quote from: thunderjet302;289710
who is gonna see that when they are at the stoplight beside you... try racing another car, not a semi...:D
an aod that slips is nothing but garbage.  once it slips there is no true fixing it.  this is a replace only job.  it will take 2 guys, a couple beers, a garage, and a jack.  ok well it took us 2 days.  but it was DONE by mid day on the second day.
I have blown up 2 AOD behind v-6's. One at 160-170,000 or so, and another at 115,000. I also blew one behind a 86 5.0 with no mods with higher mileage.
Mine had 220k (original trans) when it started to let go out of nowhere. This was shortly after the stock motor came out and a new one went in though. The Mustang one that went in to replace it was much better behaved and had a slightly higher stall. A new transmission is a huge difference after working with one at the end of its life. Adjusting the TV cable to get more pressure helped bring it to life more also.
1988 Thunderbird Sport
Sorry to hear about your bad luck with the AOD.
I guess I am lucky to not have experienced that problem yet. But then again I put shift kits in my cars right after I buy them.
The only AOD I currently have that makes me nervous is the one in my 95 F-150.
We tow our race cars with that truck and it has a 302. I am not worried about the 302 tho. The trans looks to be the weak link in that truck.
83 T-Bird 460
83 T-Bird Heritage 5.0
84 T-Bird 5.0
87 T-Bird Turbo Coupe
88 Bronco II Drag truck 302
95 Mustang GT auto
2004 F-350 CC Dually V-10
is it just me or when i see an auxiliary oil cooler on a aod car i think "yep its burned up the transmission already" or "i wonder if their coolant lines dumped too"
