Topic: gt40P heads and stock manifolds (Read 8011 times) previous topic - next topic
Has anyone treid the gt40 heads with stock exhaust manifolds?  Just curious....Was thinking of maybe clearing some stuff of my shelves
Stock exhaust manifolds are ONLY good as recycling material.
It *may* work but you'll just choke a bunch of power out of the GT40P heads, which would make it a waste of time ;)
I know those heads use a manifold that looks like a cut up and hacked up stock mustang headers. And with the angle of the plugs I don’t know. But like they stated above why waste your time. Money can’t be an issue there’s someone always giving away stock stang headers or for cheap same for the h-pipes,
There is a reason for everything!  I have headers (for gt4oP)and an x pipe to put on if I wanted to later ...However I have a little bet going on Hooptie vs hooptie.  My xr7 vs 99 crown vic..So I need it to appear stock..For now.  I even have an extrude honed upper and lower which made 314rwhp on my stang....So I think I can do it..I would perfer to besat him by quite a bit..I may try some porting of the manifolds..But I dont know
It has to be stock?Your car should beat his without the new heads then.If you DO decide to install the heads,and use factory exhaust manifolds,you may need to install new plug boots on the spark plug wires to help clear the manifolds.Are you guys going to be inspecting each other's cars?I don't see what would kill you by installing the headers and X-Pipe.How do you know his is totally stock?Installing the Extrude honed parts and heads is pointless without the exhaust as well.Just leave the car stock until you're ready to do it all the right way.That's a lot of work just to prove you can outrun a Crown Vic.....which in my opinion,doesn't really leave anything to brag about anyway.
All I really need to do is find out if the factory manifolds will clear.  Restrictive as the wanna be dual exhaust on my car is its staying for now.  If the gt40p dont clear I have a set of gt40's I can use. I can always do the exhaust later if I like.  But for now it will be what it will be
Use the GT40s. They have the same ports and valve size as the Ps. The only difference is the sparkplug angle.
Bruce I know..I also thought the GT40P had a smaller exhaust valve . Flow numbers are different as well
Quote from: DamonSlowpokeBaumann;288860
Thats new to me. I worked at a machine shop for seven years and never noticed any difference in the two.
I am trying to get ahold of a gt40 explorer engine instead....But I WISH I KNEW THE ANSWER!!!
Iron GT40 1.84 intake valve, 1.54 exhaust valve.
Iron GT40P 1.84 intake valve, 1.46 exhaust valve.
The GT40P has a better flowing chamber so Ford could use the smaller exhaust valve yet still get the same flow out of the head as a Iron GT40 with a 1.54 exhaust valve.
That I knew however it seems there is still the debate on whats better...... Me I have no idea
But what I reallly wanted to know......WILL MY CAST IRON MANIFOLDS WORK!!!!:O)
Head flow chart.
Quote from: thunderjet302;289185
P's also have a slightly smaller combustion chamber....
