Topic: Stock Mustang K member on an 86 tbird? (Read 4082 times) previous topic - next topic
Quote from: 86sonicbird;288583
thanks guys, I was thinking of swapping since the car is tore down.
IMO, keeping the current K-member and getting Chuck's type 6 mounts is the better way to go.  The 86.5-88 front suspension allows more travel and stability than the older version.
I'm going with an oddball engine and have Mustang swap headers that require the clearance of the stang style K-member.  I also have the type 6 mounts, but will use them with the Tbird K-member if and when I get another car....preferably an early 80's Capri, but will settle on just about anything that it will fit under.  Doing a swap in my case kills two birds (no pun intended) with one stone.
1987 TC
