Topic: 86 turbo coupe resto (Read 5511 times) previous topic - next topic
yea im going to try and make it to jefferson with a friend on sat
84 TC - under contruction
2018 F150 2.7 4x4 STX
98 F-150 XLT - 4.6, auto, 4x4, extended cab
well my dads 4.6 f150 lost a head gasket so that has been comsuming most of my time.  we are almost done, hope to fire it up tommarow.  i have sanded down some of the bay in my car and should be able to start painting it soon.  i think im just going to use rattle can gloss black paint from an auto parts store.  any suggestions?
Quote from: croga001;292051
motor is out so is trans and now im just cleaning up to repaint the bay.  any paint suggestions?  do i need temp resistant paint?
High temperature paint isn't needed in the engine compartment. If you are using spray-bombs, just use a good quality product. If you are using automotive enamel or urethane, you will have no problems at all. In fact, I frequently paint engines with regular urethane with no problems due to heat.
Shiny Side Up!
Bill
ok thanks i was thinking duplicolor gloss black automotive paint
what did you do with the body kit??
