Topic: Original cars, owners, documentation (Read 116272 times) previous topic - next topic
Reply #90
I'm pretty sure my '88 has the same marks on the inside of the fuel door.  I will have to check it out.
Reply #91
Heres a thunderbird dealer brochure for 83 that I found in a junkyard car, full color, lists all the options and colors available[/IMG][/IMG]
Reply #92
I found out that my car was built on 09/22 in 1987. Since I'm crazy about cleaning I removed the date stamp (by accident) on the radiator support when I detailed the engine bay. I decided to have a stamp made up so I could reproduce the date stamp. I think it turned out pretty good :D. I also have a clearer picture of the paint marks on the transmission dipstick tube.
Reply #94
It was only $5 bucks so not bad. I found a local guy who car pretty much make any rubber stamp you want. No one sells yellow ink however so I had to use water based paint to stamp the number.
Reply #95
Looks good man.......most folks use the model paints when doing the stamps.  You could try that if you detail the stamping off again. :D
tbirdregistry.com
26480
27373
Reply #96
I used water based Testors model paint. Hopefully it lasts.
The New Aero Bird
Reply #97
Easy to forget just how radical the 83 Thunderbird was when it was introduced.
X
tbirdregistry.com
26480
27373
Reply #99
My cars born date is 6/4/83
Reply #100
Quote from: rodsterh;389815
According to this Ford commercial, the new Aerobirds were first available February 17, 1983.
http://www.youtube.com/watch?v=6ytPXxAClhE&feature=relmfu
This commercial is also perfect
[video=youtube;ZoqFIumotf8]http://www.youtube.com/watch?v=ZoqFIumotf8[/video]
Reply #101
Quote from: rodsterh;296735
Interesting find on my 83 5.0L Heritage. While looking for factory markings I noticed the fan shroud is a E4 part number. I've owned the car from new and the shroud is original. Manufacture date of the car is 04/83.
Can all you 83 owners run out and check the part number on your fan shroud? :D
 Sorry this took me so long to do.....they are the same.
Reply #102
My factory date code......6/4/83 corresponds to my build sheet and Ford report, as well.  I also included the wheel lock sticker from McGuard from the trunk, the spare tire instructions, and the hidden location of the keyless entry code.  Buck tag, build sheet and Ford report all here in one place.
Reply #103
The '84 part number might be because the 5.0 kinda sorta delayed the production of the '83 models. Originally the 5.0 was supposed to be a running option but I believe they were available from Feb. 26th. Ford might have just switched the fan shroud part number from E3 to E4 as a result. Not positive but it makes a lot of sense.
Reply #104
a few more items for the archives:
