Topic: Original cars, owners, documentation (Read 116045 times) previous topic - next topic
pulled everything out of my interior just to find
the build sheet .never found it .also checked the
trunk. what do you want to see? paint dobs,spring
tags.original hoses, key tags window sticker? my car has pretty much
everything from day one. mine also had some one break off the buck
tag years ago though
now that you mention spring tags. for all the rust on my car, most of the tags were still on it. I did save what I could as far as tags. everything on my car was still original when it got put away.
let me know what were looking for, I'll help.
Quote from: EricCoolCats;287559
Almost all of the 1983-88 Cougars and T-Birds were built in Lorain, OH (H in the VIN). For at least part of 1985 Ford also concurrently built the Thunderbird/Cougar lines in Atlanta, GA (A in the VIN). After 1985, production shifted exclusively to Lorain to allow Atlanta to build the Taurus/Sable in 1986.
The Atlanta VINs are not the same as the Lorain VINs. In other words, you could have H101234 and A101234, just as an example, at the end of two cars' VIN numbers. It gets weird but that's how Ford assigned VINs. Just FYI.
I have original 1984 and 1986 documentation for my current cars (Ford 999 report, built sheets, buck tags) if it will help. Probably the biggest area for collaboration will be for the original radios. Each radio type has a code on the built sheet, and that's the only place where you'll find that info. If you know what original radio was in your car then we can figure out a database for those. There will be some other areas (fabrics, outside trim, etc.) where we just have to put our heads together and deduce things. AFAIK nobody has really tried to decode the build sheets objectively for our cars. I'll help all I can.
Interesting info..thanks!
I've seen quite a few 1983-1985 "A" Atlanta VIN cars so I wonder what the ratio of Atlanta cars is to Lorain cars?
I have one of each (83's TBirds) and the Lorain car has a buck tag and build sheet under the seat, and the Atlanta car does not. Where was your 84 built? Did you find a build sheet or have a buck tag?
I also found some paint stamps on the Lorain car but not the Atlanta car. I know in the Mustang world Ford operated differently in different plants so I'm sure that holds true for Thunderbirds/Cougars too.
Another weird thing to remember about the VIN is the consecutive unit number does not necessarily relate to a production date.
I have not looked at my build sheet yet so I 'm not sure if it lists a build date but I find it odd the data plate on the door jamb only has a month and year, no date.
Any info any one has to offer, including pictures and documentation, would be helpful.
tbirdregistry.com
26480
27373
Quote from: daminc;287628
Those spring tags sure seem durable! I don't know what kind of material they used but they sure seem to last.
My suggestion to anyone who is interested in this kind of stuff would be to take pictures, including close ups and keep a file of everything you find.
When sharing the info, make sure to specify the year, build date and assembly plant.
Patterns will probably emerge at some point and it will probably relate to the codes on the build sheet.
Don't know if these cars will ever be the 'big buck collector cars" but if you have a good car, lots of documentation is always useful.
tbirdregistry.com
26480
27373
Quote from: daminc;287578
I got mine and I'm afraid to remove it.
Great picture of the build sheet!  I think the key to removal will be to unhook the springs which should make it much easier to remove (in one, or two pieces) :D
I have the same task ahead and experimented on another seat first. Odd place to put the build sheet....
Let us know if you get it out.
Rod
tbirdregistry.com
26480
27373
Quote from: rodsterh
Well, you have to remember that I live a little over an hour away from the Lorain, OH plant so I tend to see nothing but Ohio-built cars. Atlanta cars are very rare here. But not just for that reason, I still believe Atlanta cars are pretty uncommon. My guess is about a 15- or 20-to-1 ratio. Obviously you're going to find more in the southern U.S. than anywhere else. And visually they look the same, so there's really no way to check until you see the VIN plate. Hard to do on the freeway LOL.
I never did get the full story about why there were two plants building our cars during one model year, although according to the books that I have, the most aero-Fox Cougars and T-Birds were built in 1985. With two plants building them, that's not really hard to do! Apparently there was a lot of demand for them. That was a little before my serious interest in these cars, unfortunately, so I don't know much about that.
For the record, my '84 is Lorain built and I have both the build sheet and the buck tag for it. Same with the '86. Build sheets were in the passenger seat frames as in Jerry's photo.
Some people have reported finding build sheets under the rear seat cushion or behind the rear seat panels. An old, old Ford custom was to place them on top of the gas tank although I don't think that happened with our cars. I suppose it's even possible to find the build sheet underneath the carpeting, for the adventurous.
For the build date, there are a few places on the car where you might find something dated, especially with the 1983-84 cars: rear quarters inside the trunk lid lip; top of the cowl, under the hood; side apr0ns in the engine bay; sometimes on the K-member. I've found that those dates are generally within a month or two of each other. This indicates how fresh the parts were and gives a good, general timeframe that usually coincides with the door tag build date. I think the reason why a specific date isn't found may be because Ford scheduled the cars to be built during a particular week sometime. Back then they weren't as optimized with their computers as far as scheduling builds. Today, with modern techniques, more computerization, and robotics, it's probably standard practice to narrow down a car's build date. Back then, not so much.
My step-mother was the original owner of mine. She bought it new in 1984 in Sumter, SC and kept it all this time. It's definitely a Lorain car because it has the "H" Vin code. I do have the original window sticker, the owners manual, bill of sale and a virgin front license plate bracket complete with screws that has never been used. It was $13816.00 new. The buck tag is on the radiator support, however the build sheet disinigrated under the seat into a million brown pieces and it had to be cleaned out from the springs.
http://www.tbirdregistry.com/ has a small sampling of cars and it seems to be about 2 out of 3 cars are Lorain, but the database size is so small who knows how close it might be. Of course Ford probably has the numbers somewhere!
No surprise 85 was a big year. Remember Bill Elliot, Bob Glidden and all the coverage the Aero birds and Cougars were getting by that time?  I also remember very well how much excitement there was for the new body style and the push Ford had going on for these cars. I really think Ford did their homework on design and quality.
Same for my Lorain car but nothing for my Atlanta car and I have it apart, carpet out, etc. Maybe a build sheet is still hiding somewhere but I didn't find it yet.
Actually, my 65 and 68 Mustang have a build date (month and day) so I'm not sure why Ford went to month/year on the 83 to ?? cars.  As you said, many parts are still date stamped, usually a 2-3 week window before the actual build date.  I need to check these on my cars.
For starters, I'll be curious to see if anyone else with an Atlanta car has a buck tag and/or build sheet.
tbirdregistry.com
26480
27373
The build sheet for my car, or I should say what was left of it, was on top of the gas tank. I found it when I dropped the tank to change the fuel pump. There was a piece of tape and one very small corner of it left. There was just enough of the printing on that corner that you could tell it was the build sheet but it was useless other than that.
I have 99% complete build sheet that I recently acquired from another member here that is from a 1986 XR-7 and he said it was also found on top of the gas tank so they did still put them on top of the tanks at on at least some of the cars.
As far as build dates go, there was a build date that was “ink stamped” on the car when it went down the line. I have found that most ’85-’86 cars have it on the driver side shock tower and that most ’87-’88 cars have it on the radiator support. It is a yellow number with the month and day. Most likely though it will only still be there if the engine compartment was never thoroughly cleaned as it doesn’t take much effort to wipe it away if any kind of cleaner/degreaser was used.
Here are a couple of examples. The first is from an ’85 XR-7 that was built on June 25th (6 25).
The second is from an ’88 Turbo Coupe built on June 28th (0628).
Note that the date stamp on the ’85 car has a single digit for the month of June “6” and the there is a space in between the month and day.
Where on the '88 car it is a two digit for the same month "06" and there is no space between the month and day.
Brent
One of 1,246 built
Quote from: BCA;287706
Brent
The '88s also havre the date on the buck tag...
The '87 Sport I junked had the build sheet inside the left rear interior trim panel... I dunno if I kept it, I'll let you know if I still have it...
As far as production, I'm guessing Lorain was also building vehicles other than Birds & Cougs prior to '86... I know they built Econolines, but that was a totally different line... Anyway what I'm saying was there wasn't any great difference in amount of cars produced from year to year... Actually there were almost as many built per year after all production shifted to Lorain... Remember they are only going to build what they can sell...
From NATO
Turbo Coupes:
1983: 12,566 of 121,999 Total Thunderbird production
1984: 14,744 of 170,551 Total Thunderbird production
1985: 20,804 of 151,852 Total Thunderbird production
1986: 21,315 of 163,965 Total Thunderbird production
1987: 23,833 of 128,123 Total Thunderbird production
1988: 35,271 of 139,411 Total Thunderbird production
TOTAL TC's: 128,533
Turbo Cougars:
1984: 6,171 of 131,190 Total Cougar production
1985: 7,860 of 117,274 Total Cougar production
1986: 6,504 of 135,904 Total Cougar production
Brent
Actually...mine has this same thing, on the shock tower. I cant remember if it's on the radiator support or not, but its definitely on the tower in that same exact spot. I was so excited to see it once I figured out what it was.
My son and I do 87/88 TCs, so we may be able to help with those. We've got original Ford "87 & 88 Color Trim Selections" books and all "87 & 88 TSBs". I am sure some weird combos may have slipped by, but we know what was supposed to be built and how it was supposed to be serviced....
1987 Turbo Coupe - Son's car
1934 Ford - My project car
This is the window sticker for my car, an 88 XR-7 built at Lorain in November 1987.
The build sheet was found under the rear seat cushion.
And the buck tag.
Build Date ???
Does the buck tag show an 11/30 build date?
The back of the window sticker shows 11/20/87
Warranty I D Card and Wheel Lock registration card
