Topic: quiet high flow exhast system (Read 3464 times) previous topic - next topic
Thrush Turbos are quite yet still have a nice rumble,,and arent expensive
1979 Mercury Cougar X R 7
White w/ Maroon Vynl Top
Maroon Interior
302 BIG HP IN PROGRESS
Quote from: jcassity;287860
and the 88 3.8L has no adjustment to the fuel pres regulator unlike the 87 and earlier.
Most bone stock Fords run too rich as it is from the factory.  The decrease in backpressure WILL benefit....
It's not uncommon to put a bone stock S197 on the dyno and see A/F ratios in the high 10 region @ WOT.
From the videos i.ve seen i think i really like the Dynomax turbo so thats probably what i.ll go with... once again guys thanks for the advice  and expect to hear it on you tube after completion
Keep in mind a 3.8 will sound like doodoo with a high flow exhaust if not done properly.
Are you going dual?  Single? Cats no cats?
I hav eallot of experience making 3.8's sound decent and flow well...Let me know
Wow really...that's pretty dang rich....
~John~
Any resonator style er, such as Borla, Magnaflow, Dynomax, etc, will sound decent with the 3.8L.  Just make sure you pick ones that are about the same size as the factory lers.  They will give you a little rumble, since you aren't running the cats.
I wouldn't advise running a chambered ler, such as Flowmaster, Mac, with the 3.8L, because it will sound very un-refined.
With a bigger V6 engine such as the 3.8L, its always better to be on the quieter side.  They don't sound very good with a loud exhaust.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
Find the kind of lers used on a Grand National.Those had a VERY nice,deep mellow tone to them.Not too loud either.Made the 3.8 in the GN sound really intimidating.
gm cars have a different sound all together, I heard them w/ aftermarket s even the later model V6s. what do the guys w/the supercoupes run they had the 3.8 ford motor.
Quote from: DamonSlowpokeBaumann;288392
I'm going dual w/ no cats. Its in the original post... i have decided, however, that I am going to go ahead and get headers first and get all of the exhaust work out of the way at once... getting a pair of used factory stock 95 v6 mustang headers. Pretty sure those will fit... however, looking at the headers there are o2 sensors in both but my car only has one on the DS. My tech book for the car also says I should have two in the car, but I have nowhere to put one in on the stock manifold or anywhere to plug it into a computer harness, so I guess it is unnecessary. I'll just plug weld up the hole in the header or something...  but will putting headers on it make it pretty much impossible to keep quiet? I'm not going for stock quiet,and I'm not really looking for that flowmaster throaty growl or that  honda fart can either... I'm just trying to find something that will give that race car "scream" without g off every cop and neighbor in the city.
