Topic: 4.9 inline 6 swap (Read 5823 times) previous topic - next topic
4.9 inline 6 swap
most of it will just be getting the 300 to fit in there. If it were me, I would get a carbed f150 i-6 with a junk motor or tranny to line everything up and see if the tranny could work. I would also use motor plates to not have to deal with motor mounts. I firmly belive that the 300 will fit in with minimum modifications.
4.9 inline 6 swap
well, we will find out once i have done my research and know what has to be down. then the fun part comes on getting it to work and making everything fit
4.9 inline 6 swap
I'll be watching, as I'm considering a 300 6 swap into something as well. :)  I have a spare efi engine out back and a carbed one in my bronco, so if you need measurements or anything let me know.  The bell mating surface stayed in the same spot for both the v8 and 300, for starts.
1987 TC
4.9 inline 6 swap
I know for sure a 300 will fit in a Fox Mustang, because I knew somebody with a '79 Mustang with a 300/C4 combo in it. The car was a shiznitbox, originally a 200 i6 (leading me to believe that the I6 crossmember would be necessary), and the engine was hacked in, but it was in there. The hood closed over it fine too, but he had a Capri hood on the Mustang (and the hood was about 4" too long, so it hung out over the grille - like I said, a shiznitbox)
4.9 inline 6 swap
I don't know exactly how the I-6 K-members are set up, but the oil pump is almost dead center of the engine(front to rear), if I remember correctly.
The fact that it doesn't use a crossflow cylinder head really limits performance also....a years ago, somebody was making an aluminum crossflow head, but it had NO coolant passages.
I remember coming across a (volvo?) cylinder head swap for the 200 or 250 that really makes a huge difference with minimal effort.  I think the 200/250 swap would be much more feasible...but I guess where's the challenge in that?
4.9 inline 6 swap
You guys should consider the Australian 4.0L I6.  Engine Distributors Incorporated in New Jersey imports the NA version for the industrial market.
