Topic: window clip glue epoxy (Read 19820 times) previous topic - next topic
Windshield adhesive stuff can flake off or come off in chunks. I'm not sure how hard it would be to actually pry it off of the window, but they make replacement clips that you can pick up at autozone now. I would assume you could just take a knife of small hack saw blade and cut between the window and the clip.
I also drilled smallish holes in the clips, and sanded the window really well before I did it, as well as cleaned it up good. I do not think I will be having issues with at least the drivers side any time soon.
The passenger side I need to lube everything up now that I have it working and re glue that window. I honestly never thought it would hold. When I put the adhesive of and tried to roll it up, the window went up, but the track never moved and all of the adhesive I so carefully put in smeared really badly, and that side is holding very strong. I would just like to get it in the right orientation and lube the track up good so that the window will roll up faster. Right now it drags pretty good the last couple of inches.
