Topic: which 6-speed to use (Read 3678 times) previous topic - next topic
i am going to put a 6-speed in my bird. which one should i use?
the Richmond or the Ford Motorsport. i have a turbocupe parts car that i got the clutch peddles out of. i am going to get a new drive shaft. going with aluminum, and i know i will prob have to have it modified. also any one have any opinions on which clutch i should use?
 :barf:
1963 Lincoln Continental Cov. 430ci
1984 Thunderbird Elan 302ci
2003 Ranger Edge 245ci
= 977 total ci  :flip:
1963 Lincoln Continental Cov. 455ci
1984 Thunderbird Elan 232ci 3.8L Super Coupe "in swap stage"
1998 Lincoln Mark VIII 4.6 280CI 4.6DOHC V8
                        :birdsmily:
Re: which 6-speed to use
what kinda engine mods? if you got nothing i'd get the ford one, with stock mustang clutch. if your hard core, id get a TKO with spec 2 clutch
awsome...
sounds awfully expensive :barf:
let us know if you can get it to fit.
~John~
well, not sure what im going to so. i know i will prob at some point do a 351C build. thy both use the same bell housing. so i should prob go with the bad boy, how would the tko fit? if i use the ford one. it will fit in all the right places. but the drive shaft would have to be changed. the cross member prob would need modifying.
 :barf:
                        :birdsmily:
I know for sure you can get a tremec t-56 on a 5.0 or 351W. You will need to shorten you drive shaft, move your transmision mounts back, use 31 spline yolk, and specific bellhousing and clutch just to name a few but the list goes on.
