Topic: Project thunderstruck! Update 3-11-13 (Read 37307 times) previous topic - next topic
Reply #45
I do have a few relay questions. in the pic above there is a wire that runs next to the passenger strut tower what does this go to so I know what relay to get?  and also next to the computer there is another relay what is it? Thanks in advance
Reply #46
as far as the title goes for this thing I'm gonna have to contact an attorney to go through the court and have the judge award the car to me. I guess if I want to save this thing bad enough I'll do what it takes to do so. does anyone have any ideas on the relays asked about above? Thanks
Reply #47
I was told that the one on the passenger side fender well is for the a/c.The other one,I'm not sure.
Reply #48
The one next to the eec *may* be the fuel pump relay...they're in close proximity to each other...
Any progress is good :D
Reply #49
The fuel pump relay is in the trunk between the inner rear fender and structual support....under the package shelf area.
Reply #50
yeah the fuel pump relay was already with the harness and is installed in the trunk. I think this is where Jcassity and one of his helpful posts is needed :D
Reply #51
You're right..the relay I was referring to is the eec relay...brain fart I guess:punchballs::D
Reply #52
new question, are relays the same internally? like if I were to use my old antilock relay for the A/C or EEC would it work?
Reply #53
Well, I had the wrong one in the connector for the eec....and the car wouldn't start :hick:...
BUT, the relay itself was missing a terminal that the connector had, so as long as they have the same terminals I'd *guess* they'd work.
If you don't have the one you need, text me a pic of the connector, and I'll send you one..I have several here ;)
Reply #54
here are are the pics of the relay plugs you asked for Beau. the top is the EEC relay and the bottom is the AC relay.
Reply #55
about time for another update, I finally got my headlight harness all strung together with the 5.0 alternator harness.  and I have found an offroad H-pipe.  thats about all I have done for now lol.
Reply #58
Cool, the payoff is well worth it!! I'm ready for some nice weather so I can get started on mine. I just have some minor things to take care of. At least I hope it's only minor!! LOL!!
