Topic: fiberglass resin? (Read 2226 times) previous topic - next topic
fiberglass resin?
I accidentally got some of that fiberglass resin in the inside of my door on the vynail part, does anyone know how I can get that stuff off? I tried soap and water, and truied sing most of it off, but still didn't get all of it off. Anyone got ne ideas?
Re: fiberglass resin?
Hmmm, I've never worked with fiberglass resin, but I have used long-strand fiberglass filler.  If it's anything like that, once it hardens it should be able to be "popped" off.
brian is right, u have to wait until it gets hard and then pull on it
Dude.. No comment.
Quote from: 1986Tbird
:rollin: :rollin: :rollin:
The worst thing you can do is try to remove it when it's wet, because as you discovered, you'll just spread it around. Once it's hard it will pop right off because the vinyl flexes, the resin doesn't.
If you've spread it too tin while trying to clean it up it will be thin enough to flex, so it may not pick off. If that's the case acetone will dissolve  hardened resin, but BE CAREFUL - it might also dissolve the vinyl! Try it on a s piece of vinyl first!
