Topic: Quick n Dirty Spring Swap (Read 5569 times) previous topic - next topic
I have a pitsburg harbor freight set. Its my all around tool box. Its got a couple of deeps, and all 1/4 to 1/2 inch stuff within reason. And at 40$ I can't complain. I take it to junkyards all the time and have no issues. However, you want to keep that "foam" stuff. Otherwise the sockets fall out. I lost a couple from not noticing there were some out when I took it out at the junkyard, and couldn't find them.
I have a sman set 140pc plastic case that I take to the yard.  My dad has the same box but made 10 years earlier.  My kit constantly pops open spilling all the sockets (I have added a cardboard "shim" to keep the bits pressed in the plastic).  It's missing a few now too.  His has never popped open slamming around in the trunk of his TR6.
Overall, I'm dissappointed.  I haven't ever broke their sockets however.  I have destroyed a couple autozone sockets with my big breaker bar (a harbor freight find).
Quote from: daminc;280977
I'll bet you didn't read the first page. LOL
I bet your freebie image host is blocked by my company firewall... I read fine, just can't see the pretty pictures, only red x's. I'm guessing they're pictures of that kind of spring compressor?
yep, that's what it was a pic of
I did the spring swap this weekend.  What a nightmare.  DO NOT REMOVE THE A-ARM BOLTS.  This was the worst idea ever.  It's much easier to unbolt the main shock bolt and the sway-bar links.  I used an internal spring compressor tool from Autozone and aside from having to fish out the bits from the inside of the spring, it worked well.
When I Pulled the passenger a-arm bolt it wouldn't clear the steering rack.  Then, in my darkest hour, I let the jack down causing the half exposed bolt to punch a big hole in my steering rack, so I am still living the nightmare of replacing that.  Sometimes I have blackout stupid moments.
