Topic: HO cam (Read 4741 times) previous topic - next topic
HO cam
what are the numbers stamped on the back of a stock HO cam? i helped my brother put an F cam in his 88 Mustang (still SD) and it runs exactly the same as it did before, no surging, no driveability difference. we are wondering if maybe it had an aftermarket cam to start with.
86 Mustang GT
HO cam
IF it doesn't sound like this.... http://www.youtube.com/watch?v=CoRW50mLnxI
Then your brother got screwed. It should have a noticably loapier sound to it. Also, it is not a speed density friendly camshaft either.
HO cam
This is what is stamped into the back of the HO cam I just gave to Vinny.  I measured the Lobes and with a 1.6 rocker they measure out to 0.444 so its definitively a stock HO.  Perhaps your Idle is set too high and you cant hear the loap?  This is the back end of the cam (opposite the timing gear).
HO cam
Quote from: Haystack;279630
it has F303 stamped in the end of it.
the came that came out looks nothing like the one in the pic. the only numbers on it are "08" and there are two dots and a notch.
86 Mustang GT
HO cam
Quote from: Dougy_Fresh;279667
1. Anyone can stamp letters into the end of a cam, I hope he bought it new.
2. If it doesn't idle like that vid the cam isn't what he/it/you say it is.
HO cam
Sounds like he got stuck.
I got a B303 cam in my mustang and I can tell a big difference. But then again I have a few more mods done to it.
Did he buy the cam new?
1971 Camaro Blown 640ci
1988 T-Top Mustang
1980 Mustang coupe
1988 Thunderbird TurboCoupe
Previous Thunderbirds:
1988 Sport
HO cam
no it was used.
any way u go about it i ended up with a HO cam.
86 Mustang GT
HO cam
Thats one thing I wouldnt buy used unless I knew for sure what it was. Cant really tell what it is by looking at it.
1988 T-Top Mustang
1980 Mustang coupe
1988 Sport
HO cam
the car is starting to lope a little, but it's like the computer is not letting it...or the iac is keeping it idled up.
86 Mustang GT
HO cam
What rpm is it running at?  What is your base idle speed set at?  if its idling around 1100 it won't lope.  What does the butt-dyno say?
HO cam
he says it picked up some on top and lost a little off the bottom, based on the butt dyno.
i think its idleing at 1000-1100, we cant get it to go much lower
86 Mustang GT
HO cam
Should be able to go 180mph now, huh? lol :mullet:
HO cam
Get the engine warmed up.  Disconnect your Idle Air control solenoid. Then adjust the screw  for the throttle stop.  Do your rpms come down?  I am not sure what a SD computer will do with a F303 cam in it.  I think they run rich.  Sooty exhaust?
Seems like alot of effort to stamp F303 on a stock cam.  Also, did you pick it up from his house?
HO cam
Quote from: Sick88Tbird;279735
:hick:
HO cam
If it's SD you aren't going to be able to idle a "F" cam below 1100 and keep it running... It'll just load up and eventually die...
