Topic: Finished Sons Turbo TC!! Pics!! (Read 5523 times) previous topic - next topic
Quote from: RDOG;278403
yep. I sealed them and redrilled them. Then I just took stock rotors and had them drilled to 5 lug too(didnt seal those though, just redrilled them)
Lotz of questions.
Who did the drilling ? Think I can do it using a drill press ?  How did you seal them ? What set up did you use on the front ?
1974 Falcon XB-GT Coupe
1988 Thunderbird Sport
1962 Thunderbird convertible
1971 Mustang Mach1 429SCJ
Great looking car.Nice work.
Quote from: Mr-Mach1
Lotz of questions.
I used 92 lincoln mark VII front rotors. direct swap that took less than 30 minutes. I had a local machine shop do the rear axels, so I dont know what he did exaclty, just glad it could be done. He now has a jig using a ranger 5 lug drum I brought, so I can make more whenever I want.
Quote from: 1WLD BRD;278832
nice car, but why is the back, passenger side of the hood sticking up in the air?
The hood sticks up because I just can seem to align it! Everyone I have spoken to tells me that its never quite right once you remove the hood. If you have a secret, please let me know.
Quote from: Live Fast;278847
Where do you buy these clear corner lights?
Also would it be possible to get a video of it at idle? I want to hear this cam!
I made them myself and you dont have to break them open to do it. Takes me less than 15 minutes per side. All you need is a long screw driver, hammer, and wire snips.
1)You take the long screw driver and hammer and stick screwdriver into bulb hole to crack the yellow lens into peices.
* A slightly bent large thin screwdriver works great
2)Once its in peices you just maneuver the broken pieces towards the bulb hole.
3)Then use the wire snips to cut the broken peices up into smaller peices until the broken pieces are big enough to fall out the hole.
4)Then you rinse out the remaining debri and let it dry. Wallah, clear corners.
Son's TC??? I did not think you where that old for some reason, I thought you were around my age. Nice job on the Turbo Coupe. :)
Quote from: RDOG;278926
Nice tip. Would of never thought of doing it that way.
Alligning the hodd is easy... I have taken them off and re aligned them many times..  just got to keep playing with it til it is right...
Good looking Bird
Love it!
It came out great! Looks sweet! Thanks for the tip for the clear corners. I'm going to give it a try, I have extras I can try it on.
that clear corner trick is freakin awesome.
i had been wanting to do mine ever since i got the car, but didn't want to take the chance of messing them up cutting and resealing them. so today i tried it this way.
i was done in under 10 minutes including pulling them out and putting them back in.
86 Mustang GT
Reply #39
When I take the hood off, there are rust holes left over, so its easy to line it back up. You have problems when you take the hinges out though.
Reply #40
Quote from: Dougy_Fresh;280871
I love how you guys do stuff ive never had time to do myself. :bowdown:
the only conflict i think there is to the clear turn lamps is the lense is not yellow, however the bulb being yellow may fix that whole tecnicality.  for state inspection purposes, me thinks the yellow lense doubles as a reflector and is required color coding for corner front left/right while the rear is red left / right.
trailors are wired the same way with yellow lenses up front , red in the rear.
