Topic: Fuse 8 - .86A draw (Read 2467 times) previous topic - next topic
Fuse 8 - .86A draw
I can't wait for my wiring to start going to . One day I will rebuild the whole thing. Hopefully by then I will have a garage.
Fuse 8 - .86A draw
Try reversing the meter leads and see if you still have 1.2 ohms.
Ohm meters apply a voltage to the circuit. There are diodes in the car between + and ground. If the meter voltage is high enough it can forward bias the diodes and measure a low resistance.
Fuse 8 - .86A draw
So, apparently this is 99% my own stupidity. I have a dead map light/not turning on but the switch was on. After flipping the switch up to the off position, the current draw is now 15 milliamps. I understand why I didn't notice it due to the lack of a glow but , I didn't think of checking those switches. I guess this is good but a HUGE waste of my time. I still don't know how it got hit as I didn't do anything on that side of the car or rear seat - just get in, drive 2 miles up the interstate, get out, get in, drive back, get out.
Still seems like a weird coincidence that my alternator isn't charging at the same time.
CHECK THE SIMPLE THINGS!
1988 Thunderbird Sport
Fuse 8 - .86A draw
Quote from: TurboCoupe50;277145
Not so, cold filament resistance in any bulb is FAR LESS than when it's lit... Most bulbs are only a few ohms cold...
well,, hey,, think about it though tom
he may have some strange new fangle headlamp bulbs other than stock.
A filiment bulb is pretty much a continuity check as in no way near 1k unless the bulb is some fancy blind you at night deal.  Ive never read what the halogen bulbs read,, figured if they arent lit and dont work in a known good socket, toss em in the garbage.
I think what might be a decent idea for you is to modify an evtm page with the wriing diagram you desire to focus on and then white out the circuits you have removed and insert what you have added.  this will give the ole memory a chance to forget about it cause you have it documented.
I had to do this with the bronco trailer wiring,,, i confussed myself one day trying to figure out what i did 8 years ago by using the hitch as the only light ground.
Fuse 8 - .86A draw
Quote from: jcassity;277216
I thought about this but it seemed too complicated :p I'll likely be adding a 4 gauge wire to the stock fuse block location and adding a second fuse block in the vicinity just to have a more stock-ish setup. I cannot find a large fuse block though - I want each part to have its own fuse. I see where Haystack is coming from.
I may have not been thinking 12v clearly with my "1000 ohm" bulb when cold statement but the fact still stands that it is much more than 1.2 ohms when cold, unless it is a 120w bulb on the 12v system. I assume this is lit though? I don't claim to be an electrical genius.
Voltage^2 / Resistance = Watts
Voltage^2 / Watts = Resistance
Fuse 8 - .86A draw
Measure the resistance of a few bulbs, you'll get the idea... Resistance increases probably 6-8x when they are hot, only then does Ohm's Law apply... So assuming your .86A current draw was a lamp, if it were lighting, current may have actually been 150ma(.15A)...
Even the resistance of a electric motor will decrease dramatically running vs locked... Current draw of coils & solenoids can usually be determined by their resistance readings... And solid state electronics??? Forget measuring resistance, same applies to anything that's powered by a transformer(AC circuits), secondary load is the determining factor here...
Fuse 8 - .86A draw
OK I have here on my desk a GE 1157 bulb. Standard tail/brake light.
One filament is 2.2 ohms and the other is 0.5 ohms.
Fuse 8 - .86A draw
Wait - same bulb? Anyways, they should be a whopping 6 ohms when lit? Rated at 27w/12.8v.
Fuse 8 - .86A draw
Quote from: softtouch;277311
The 2.2 ohms will be the general illumination filament, while the 1/2 ohm will be the stop/signal filament...
Fuse 8 - .86A draw
Quote from: TurboCoupe50;277353
Oh, duh :p
